@dudley_1972 avatar
Vespa Douglas Sportique (VBB), PX200E, 50N (smallframe), Lambretta LI 150 (SII)
@dudley_1972 avatar
Hey guys, I have a SIP digital speedometer and it's causing me problems. After a few minutes of running it generally freezes up , the Rev counter won't work and CHT stops etc, have just read somewhere on SIP forums that you need to change to an R-type spark plug, this has a built in resistor which suprsses engine noise that causes electrical problems so will post the results after I've got hold of one.
@dudley_1972 avatar
@dudley_1972 avatar
I can confirm that I have fitted an R-rates plug : BR8HS, I have done around 50 miles on this plug and the speedo is working fine, hasn't frozen up once, hope this helps.
@scooterraton avatar
2 - Many
2 - Many
My problem was a lose ground wire.
@dudley_1972 avatar
@dudley_1972 avatar
You won't believe this but over the weekend my CHT sensor has stopped working, probably a cable snapped somewhere, have an idea that it could be a cable in the headset that's broken...Fixit On Repair Daily as some might say or FORD!
[ Time: 0.0094s ][ Queries: 3 (0.0031s) ][ live ][ 313 ][ ThingOne ]
