Hey Guys - never did like the burnt out headlight look on MP3's - has anyone attempted to upgrade the lights say with a H4 bulb so each headlight is dual beam and lit.
Mon, 25 Jun 2018 01:05:25 +0000
Thanks |
![]() Mon, 25 Jun 2018 01:34:21 +0000
2008 MP3 400
Posts: 258 Location: Land of Oz |
![]() 2008 MP3 400
It would require quite a bunch of wiring and new bulb sockets to do what you suggest. Here is an easy way to have both bulbs on all the time. This is the way I run my MP3. At night you can still turn off the high beam and the flash to pass still works.
Thanks to Jimc for posting the links in much earlier threads. A simple search would have returned many relevant threads on this subject. Suggest you use the search function next time. Wiring diagram: http://www.wotmeworry.org.uk/bothlamps/instr/hlswitchfuoco.pdf Pictures: http://www.wotmeworry.org.uk/bothlamps/
Positive
Mon, 25 Jun 2018 01:59:38 +0000
Let me make sure I understand . . . .After the re-wire, on high beam, I'll now have low and high at the same time - and on low beam position I'll only have low - is this correct?
Thanks |
![]() 2016 MP3 500 Sport ABS
Posts: 249 Location: Cedar Rapids, Iowa |
![]() 2009 MP3/250, 2012 GTS Super 300ie
Posts: 4300 Location: Marietta, GA |
Mon, 25 Jun 2018 11:50:29 +0000
I have had mixed results...
That Headlight suffers from Leakage and Lens Fog, after Modifications. ![]() ![]() I did the switch mod, very easy to remove the spring to Run Dual Headlights. Updated to the Brightest Bulbs I can find, and still have the OEM Light with no changes. What you could do is purchase a Used Headlight, and Experiment on your own. That way you have the original to put back in if you choose to do so. On my MP3/250, I am running the Headlight for the MP3/300 Hybrid... Very nice Chrome Insides and with the Brighter Lights with Silverstar Zxe same OEM recommended Bulb type, it works Great. On my MP3/500 Sport, I am using Silverstar Zxe same OEM recommended Bulb type. Keith, Marietta, GA |
Mon, 25 Jun 2018 12:36:30 +0000
Thanks for the reply could you explain removing the spring I don't like altering and cutting wires unless I have to.
By the way we're neighbors I live 2 hrs North of Atlanta. Regards |
Mon, 25 Jun 2018 12:40:14 +0000
LowOnCash wrote: Thanks for the reply could you explain removing the spring I don't like altering and cutting wires unless I have to. Thsnks But basically.. You remove the screw, unplug the Switch on your Handlebar. Look at the switch and you will see a small spring. Take some needle nose pliers, and bend the spring to allow the "Flash" to stay engaged. Now you will have High, Low, and Flash that won't snap back (Both lights On). Search is your Friend here... Keith, Marietta, GA |
Mon, 25 Jun 2018 12:44:53 +0000
I've been searching for two days - I get pages of everything that is not related to headlights LOL
This will be my mission for today! Thanks |
![]() Mon, 25 Jun 2018 12:51:35 +0000
MP3 500
Posts: 270 Location: Columbus OH USA |
![]() MP3 500
Mon, 25 Jun 2018 13:32:56 +0000
Buckeye Marksman wrote: Just short out the two middle pins on the four-way connector. Mike |
![]() Mon, 25 Jun 2018 16:35:48 +0000
2008 MP3 400
![]() 2008 MP3 400
LowOnCash wrote: Let me make sure I understand . . . .After the re-wire, on high beam, I'll now have low and high at the same time - and on low beam position I'll only have low - is this correct? Thanks |
![]() Mon, 25 Jun 2018 16:38:56 +0000
2008 MP3 400
![]() 2008 MP3 400
Buckeye Marksman wrote: Just short out the two middle pins on the four-way connector. |
Mon, 25 Jun 2018 17:09:16 +0000
LowOnCash wrote: Thanks for the reply could you explain removing the spring I don't like altering and cutting wires unless I have to. By the way we're neighbors I live 2 hrs North of Atlanta. Regards My regular Omelette Stop in the mornings. Keith |
Mon, 25 Jun 2018 19:26:41 +0000
klaborde wrote: LowOnCash wrote: Thanks for the reply could you explain removing the spring I don't like altering and cutting wires unless I have to. By the way we're neighbors I live 2 hrs North of Atlanta. Regards My regular Omelette Stop in the mornings. Keith Mike |
Tue, 26 Jun 2018 02:40:49 +0000
The bulbs are a pain in the butt to access, but changing out the stock bulbs to some Sylvania SilverStar Ultra bulbs makes a big difference for not a lot of money. This and the switch mod is so much better at night, especially with both bulbs lit.
Tue, 26 Jun 2018 11:06:08 +0000
LowOnCash wrote: klaborde wrote: LowOnCash wrote: Thanks for the reply could you explain removing the spring I don't like altering and cutting wires unless I have to. By the way we're neighbors I live 2 hrs North of Atlanta. Regards My regular Omelette Stop in the mornings. Keith Mike Send me a PM with your phone number, and I will text you the next time I am going that way. The Rain has been plentiful this year, and I won't Ride in the Rain. Keith |
Wed, 27 Jun 2018 01:26:11 +0000
In error I posted this on another thread when someone mentioned the headlight mod. So I'm going to post it on here as well. Here's a few images of the simple light mod that user Buckeye recommended. It works great!
PS I hope having this in two areas is not going to be a problem with the forum administrators, if so I'll delete one of them. Thanks Mike ![]() ![]() ![]() ![]() ![]() ![]() |
Fri, 29 Jun 2018 22:57:55 +0000
MP3 500
Posts: 7 Location: Chicago |
Fri, 29 Jun 2018 23:07:21 +0000
chicagorod wrote: What exactly does that mod do? |
![]() Sat, 30 Jun 2018 11:11:39 +0000
MP3 500
![]() MP3 500
Sat, 30 Jun 2018 12:24:54 +0000
Buckeye Marksman wrote: chicagorod wrote: What exactly does that mod do? Thanks |
![]() Gilera Fuoco 500ie
Posts: 4471 Location: Netherlands Olst |
![]() 2019 MP3 500 HPE Business
Posts: 826 Location: Paris - France |
Sun, 01 Jul 2018 19:31:54 +0000
Maksor wrote: Hid will burn the chrome coating better choice is LED |
![]() Piaggio MP3 500 2019
Posts: 16 Location: Nashville, USA |
Sat, 28 Jul 2018 22:27:46 +0000
Sorry for the stupid question.
Did you do this with the factory light bulbs or you changed the lightbulbs before you did the modification ? If you did what light bulbs do you recommend . Thank you very much. |
![]() MP3 250 & Sei Giorni 300 HPE
Posts: 145 Location: Auckland,New Zealand |
Mon, 30 Jul 2018 01:05:58 +0000
My dual headlight mod doesn't require any dismantling or wiring , just one small hole, small screw, couple of washers and a little wiring anchor bracket I had in my bits box.
PS. Local Piaggio dealer announced today that New MP3 350 will arrive in Auckland in October. ![]() Off ![]() ON |
Mon, 30 Jul 2018 08:10:00 +0000
Drilling a hole in the plastic seems more permanent to me than removing the spring or soldering the wires together. Both of those can be easily undone and look stock but that hole will always be there.
Mon, 30 Jul 2018 11:53:31 +0000
71Brent wrote: Drilling a hole in the plastic seems more permanent to me than removing the spring or soldering the wires together. Both of those can be easily undone and look stock but that hole will always be there. Keith, Marietta, GA |
Mon, 30 Jul 2018 13:41:11 +0000
Maksor wrote: you could also taake the spring out of the switch ![]() 71Brent wrote: Drilling a hole in the plastic seems more permanent to me than removing the spring or soldering the wires together. Both of those can be easily undone and look stock but that hole will always be there. |
Piaggio Mp3 350, 2019
Posts: 2 Location: Bergen, Norway |
Mon, 31 Jul 2023 07:48:19 +0000
71Brent wrote: Runs both lights instead of either low beam, one side, or high beam, the other side. Cheers! |
2015 MP3 500 ie Business
Posts: 1061 Location: Belgium |
Mon, 31 Jul 2023 15:30:04 +0000
Yes, the wiring mod will work with LED or Halogen BUT the real problem is the proprietary connector used in the high beam.
It is a weird and stupid design that only allows fitment of standard halogen bulbs AFAIK. The low beam is not a problem and accepts the OSRAM H7 without any issues and is small enough to leave room for the rubber dust cap. In summary, For the low beam, you use this OSRAM as it fits perfectly without any modifications. https://www.amazon.com.be/-/en/OSRAM-67210CW-LEDriving-Off-Road-Folding/dp/B07P5NRV1K/ref=pd_day0fbt_img_sccl_2/260-0813495-5952048?pd_rd_w=rgkyJ&content-id=amzn1.sym.7ce0eb2a-7f92-4245-915a-7427b7087f1b&pf_rd_p=7ce0eb2a-7f92-4245-915a-7427b7087f1b&pf_rd_r=DESJM3CA80NMFNXGZX9Q&pd_rd_wg=Vdbqz&pd_rd_r=9c405c17-41b1-46ae-ae50-7d9ddca4cbd8&pd_rd_i=B07P5NRV1K&psc=1 For the high beam, you either keep the stock halogen, a "premium" halogen (usually a waste of money), or you can try this OSRAM LED but I suspect its output will be poor and it has a very short lifespan (only about 1000 hours) https://www.amazon.com.be/-/en/OSRAM-LEDriving-HL-EASY-H18/dp/B0BQRPHC1P/ref=asc_df_B0BQRPHC1P/?tag=begogshpadde-21&linkCode=df0&hvadid=633369849311&hvpos=&hvnetw=g&hvrand=13400229458384553590&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1001249&hvtargid=pla-1967322305988&psc=1&gclid=CjwKCAjwt52mBhB5EiwA05YKo9ZHQ2GK3z7TsjXRrz5KmGb_wfyK095hJBx4Tpb8bE4RN6vVNjk5WhoCQUUQAvD_BwE FWIW, I kept my high beam stock since I hardly ever use it |
Mon, 31 Jul 2023 20:45:31 +0000
Hi! Thanks for the swift reply sbaert! I did the light mod today and installed Osram H7/H18 set. They are a 1:1 replacement for original halogen. Even fitted inside the proprietary high beam with some force.
But both cans are only lit when the high beam setting is on, or when flashing.. I thought that both cans would also be lit on low beam, but at a lower intensity light? I soldered a brigde as instructed. Did I miss a step, or is something lost in translation here Is it not possible to have both cans on at low beam/low light perhaps? Will the left side always be on highest intensity? Thanks guys! ![]() Wiring bridge ![]() High beam setting ![]() Both cans lit ![]() Low beam setting ![]() only one side lit ![]() ![]() Blinding night owl lol |
![]() Mon, 28 Aug 2023 19:56:51 +0000
MP3 500
Posts: 27 Location: Mansfield, TX |
![]() MP3 500
I am looking to do this modification this weekend. How did you get the bulb for the high beam to fit.
Mon, 28 Aug 2023 20:41:04 +0000
2016 Mp3 500ie Sport
Posts: 236 Location: California |
Quote: I am looking to do this modification this weekend. How did you get the bulb for the high beam to fit. |
