2016 Vespa Sprint 150
Hello everyone! Brand new to the Vespa world - I have a 2016 Vespa Sprint with just over 700 miles. Has a small oil drip coming from below after riding - only drips about a small amount about the size of a quarter. Any idea on why? What could possibly be loose? See photo for location of drip.
Thanks for the help!
@madison_sully avatar
My first thought/hope would be the oil filter not tight enough. Give it a twist and see if you can get it to turn.
Then check the drain plug to see if it is wet with oil.
Anything beyond that becomes bad news.
@tom_jones avatar
Vespa GTS 150 3v SUPER. Vespa V100 x 1. Lambretta Li150 x 1. Px 125 x 2. Px 200 x 1 (red bull special) T5 Classic x 1. Vespa Cosa x 2.CF moto 650mt
@tom_jones avatar
Also make sure your cylinder head bolts are bolted down to the correct torque. Mine was leaking oil and that was the problem. A loose bolt.
Tom
Seems the plug and filter are on tight. What is the best way to access and tighten the cylinder head bolts?
Sorry - total newbie on motorcycle engines - any good post reccomendations to help me get familiar with the anatomy?
@jkj-fz6 avatar
@jkj-fz6 avatar
Do you know if it has had its "first service" done yet? If not, or if you don't know, 700 miles might be a good time to have that done. The oil filter and drain plug would be checked at that time, and you could ask the service tech to look for other leaks.
Yes the first service was completed so service isn't due until 3250. Could it be a function of the engine not being broken in yet?
@jkj-fz6 avatar
@jkj-fz6 avatar
I was thinking it might even be caused by that first service, if it was done recently. The filter or plug not tight, or perhaps just some stray spilled oil running down from the filler hole.
I can't see oil in the photo. But anyway, carefully clean around the filter and drain plug so you can see any new drops coming from them. Has it dripped for long, or just a few days?
@cosmos avatar
2009 LX 150, 2024 GTS Super
@cosmos avatar
I had a small oil leak on my new LX150. It came from the oil pressure switch. The dealer snugged it up and the leak was gone.
Bill
@waspmike avatar
@waspmike avatar
Seems the answer is go to the dealership and complain and say it didn't leak before the first service. If it is a common fault they will know exactly what to do.
@tom_jones avatar
@tom_jones avatar
I concur. If you're not sure get it back to the dealer. I know its a hassle but in the meantime download a workshop manual from this forum. Have a read and things will become a lot clearer.
Good luck.
Tom.
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
Im thinking the sprint engine has the valves checked at 1st service , Possibly leak from rocker cover
Clean it up good with degreaser, dawn dishwashing soap, or whatever you have lying around. Then take a look at it after a short ride. Still a mystery? Clean again and try to dust the area with baby powder, corn starch, etc.. to help you find the source.
[ Time: 0.0191s ][ Queries: 4 (0.0100s) ][ live ][ 313 ][ ThingOne ]
