@expaladin avatar
2006 LX150
@expaladin avatar
2006 LX150
I bought the little crash bar for the front fender of my 150lx. The one that mounts via three bolts (one on each side and one in front) that you tighten from inside the fender so they kind of pinch the fender.
I'm not impressed with this set up. The bar is more clinging to the fender than it is mounted to the scooter (the rear bar assembly makes way more sense).
Anyone come up with a better solution, short of drilling holes in the fender and bolting on the crash bar?
Thanks!
@miguel avatar
@miguel avatar
I have the same bumper on my 250. It's been there 9 years and I haven't had any problems with it coming off. You might put some thread locker solution from loctite on before installing. I'd suggest the blue. It will lock it but you can force it apart. Don't use the red. It'll never come apart. I try to check it every time I do a service but often forget.
I agree is not the best solution. The body crash bars are held on the same way. No problem there either
Best Miguel
@web-tech avatar
@web-tech avatar
Best Miguel
Red does release with a little heat from a heat gun
IMO, which is the thread idea-
Given that I don't get the purpose of those guards? If they guard anything in action then you have an damage either way-with guard or not? maybe even more damage with, than without?
Dead weight and a bit cheesy for my taste but that's a personal choice.
I'd avoid the holes, return the guard and use touch-up paint if your fender gets a scratch. Mine had an edge scratch which was easily touched up with a small artists brush and some black gloss paint.
Loctite should be used on any PTW thread that doesn't have a locknut or lock washer involved-or mechanical device like a cotter key. I really like the blue solid stick, lipstick style sold in several brands. There are actually many Locktite products with lots of technical applications, blue & red are the more common versions we see in retail sale.
What fastner parts came with the guard?
@sixpence avatar
None at present
@sixpence avatar
None at present
Never had a problem with the "pinch" system.
External inline image provided by member with no explanatory textPhoto-0123 by Lesley Morrison, on Flickr
External inline image provided by member with no explanatory textNearside by Lesley Morrison, on Flickr
@expaladin avatar
2006 LX150
@expaladin avatar
2006 LX150
Just 3 bolts.
Weight of the guard is negligible.
@miguel avatar
@miguel avatar
WEB-Tech wrote:
Best Miguel
I sorta knew that because its just an epoxy and epoxy softens when heated. I don't know about how hot it has to get to soften but on the OP application where the screw would be right up against the fender, you can't apply much heat because you don't want to melt the fender.
Thanks for the tip and reminder.
Best
Miguel
Expaladin wrote:
Just 3 bolts.
What I was asking about fastners was relative to if they had a locking feature, not how many, since locktite came up, which you would not need if they locked on. I will say that many Vespa screws don't have locktite on them at least on mine. By dead weight I meant weight with no purpose, not that they are heavy in ounces.
To further make my point, let's say your fender bumps whatever, guess what? The thingy thats supposed to protect the fender(which is pretty tough & flexible plastic) gets a scratch. The result is then that you have that scratch, not the one that would have gone on the fender. Unlike a car or truck bumper which has some beef going on or actual shock absorption. There's my notion.
@expaladin avatar
2006 LX150
@expaladin avatar
2006 LX150
Gotcha. No locking fasteners. Just the three bolts. The whole little bumper is held in place entirely by friction. Wouldn't bother me if it weren't perched right above the front wheel.
They seem to be a scooter and a cruiser thing as all other front fenders on PTW's are just there no guards. Engines get the guards, along with hands.
Primavera 150 & GTS300 Super
Had one fall off going over rr tracks scared the hell out of me. It's not going back on roads are too rough around here.
[ Time: 0.0112s ][ Queries: 3 (0.0017s) ][ live ][ 313 ][ ThingOne ]
