Is there any difference in quality between the three? My stock plug is the Champion RN2C. I can't find it anywhere locally. I'm considering switching over to either NGK or Denso.
I don't know about quality differences between the three brands BUT I did notice an immediate improvement in starting and idle when I replaced the original Champion with an NGK CR8EIX iridium at 921 miles (GT200). My local NAPA dealer had it here overnight for < $10.
RIP
Hi there, I like NGK, due in part, i can find them local.
Which ever plug you do go with, just make sure it's within the heat range spec for your scoot. Cheers |
jimh wrote: Hi there, I like NGK, due in part, i can find them local. Which ever plug you do go with, just make sure it's within the heat range spec for your scoot. Cheers |
NGK CR8EIX Iridium
+1 Did nothing for starting or idle but definitely adds a few mph to the top end and gives the (Scorpion) exhaust some entertaining pops and burbles on trailing throttle. |
Thanks guys for sharing the alternative brand & model of spark plugs for our GT200, this really helps as the Champion brand is not available in our area.
Aprilia Sportcity Cube 250ie, Stella 2T
Posts: 3186 Location: Asheville, NC, US |
I just switched out from the stock Champion in my Stella to the NGK. She's purring like a kitten now and I have a few spares to boot. I had a hard time finding the replacement Champion plug.
prcrstn8 wrote: NGK CR8EIX Iridium +1 Did nothing for starting or idle but definitely adds a few mph to the top end and gives the (Scorpion) exhaust some entertaining pops and burbles on trailing throttle. |
RIP
ElGato wrote: prcrstn8 wrote: NGK CR8EIX Iridium +1 Did nothing for starting or idle but definitely adds a few mph to the top end and gives the (Scorpion) exhaust some entertaining pops and burbles on trailing throttle. |
Stupid question number two.
I know that you are supposed to change the spark plug every 12,000 miles. I'm assuming that I won't find the NGK CR8EIX Iridium at the local store so I'm going to order one online (plus I'm lazy and I like to shop online). So, in order to save on shipping, I thought I would order a couple. Stupidest question ever: Do spark plugs 'go bad'? Will a plug that sits in my garage for a year or so in the box wear out? I'm truly ashamed. |
