carnaby 125
carnaby 125
for a while its now got worse
my coolant cap makes a hissing sound after I just been running it for 10minutes its not overheating and still staying below half way and no milky colour in the engine oil
i checked for leaks on the pipes nothing is there a chance i got a slight gap on the head gasket that causing over pressure as ive tried 2 different caps but i not tried a new coolant tank yet
@web-tech avatar
@web-tech avatar
Call a few auto shops and ask if they have a CO2 head gasket tester.
You want them to test at the radiator cap (with it off) for CO2.
Link to a test kit
https://tinyurl.com/y7sekevp
Links to how to videos if you just want to buy your own kit.
https://tinyurl.com/ybhxxl6k
carnaby 125
carnaby 125
Problem is it doesn't have a radiator cap only have the coolant reservoir cap
@web-tech avatar
@web-tech avatar
Same thing. You need to see if the exhaust is getting into the coolant.
Any shop that has the tool should understand the tests needed.
There is a way to test exhaust for coolant too but I forgot how.
carnaby 125
carnaby 125
well I just flushed coolant and put new coolant and next day looked in and its grey again and theres tiny bits floating but not metal its like rubber very tiny tiny micro bits of black but waterpump isn't making a noise and no leak from that area
I don't get white smoke
Rally180
Rally180
If the coolant changed color, then you have a leak. Head gasket is most likely. A CO kit test will be further proof.
carnaby 125
carnaby 125
well im thinking of asking garage for a price of fitting new gasket and might aswell get new piston and rings at same time if its more then what the scooter worth I just might replace it with another scooter
[ Time: 0.0101s ][ Queries: 3 (0.0039s) ][ live ][ 313 ][ ThingOne ]
