@budz avatar
GTS 300 Super ABS/ASR (sold), BV 350 ABS/ASR (crashed)
@budz avatar
How do you wash your helmet removable liner/padding? I have a Shoei Neotec and a YouTube video says wash by hand with baby shampoo. Anything wrong with putting in the delicate cycle in the washing machine and air drying them?
@cadbury64 avatar
2019 Primavera 150
@cadbury64 avatar
2019 Primavera 150
I do wash the linings and cheek pads of my Arai helmets by hand; some of the foam components would not take well to any machine agitation.
@budz avatar
@budz avatar
Thanks for the reply, what soap do you use?
@ducatiterminator avatar
ET4
ET4
Woolite
Have used shampoo in a pinch or while traveling too.
Second woolite. Just make sure you rinse well. I then squeeze the wet parts in a towel and then let air dry. I do this about every other week during the summer. I also have a second helmet so I don't have to wait if I want to ride. Pro tip: when you come in from a ride during the summer months, dab the inside with a clean dry towel to soak up any moisture and then put a dryer sheet in before wrapping up in the helmet bag.
A do rag helps. Get a bunch of the and you can wear them once and wash. Thankfully mine doesn't smell. After a ride i leave it on the table to wear out. I got a helmet cleaning kit from Hedon and i spray a little of their helmet stuff inside and i'm good to go.
Dark Woolite-my wife has it on hand.
@haole avatar
2007 Vespa 250 gts / 1964 Vespa VNB / 1961 Lambretta Li150
@haole avatar
On my second Shoei, love that I can remove the whole padding.
I put the pieces in a laundry bag and throw in with dark colors, then air dry.
Living in Phoenix I wash mine a lot.
No issues.
1967 VBC 150 (Sold) 2013 SYM Wolf Classic (Write-off) 2005 PX150 2016 Primavera 150
I just use Tide hand washed..no issues so far smells fresh n clean!
@troutbum avatar
@troutbum avatar
I machine wash cold water using regular laundry detergent. In-between machine washes I use a solution of white vinegar cut with tap water on a micro fiber cloth to wipe down the liner.
@budz avatar
@budz avatar
thanks everybody, the Woolite worker very well
I just had a chuckle. Laughing emoticon I wonder if anybody has thrown their whole helmet in the washer to clean it. Nerd emoticon
@fencing_fan avatar
2018 GTS 300. Montebianco
@fencing_fan avatar
Nah; too much crashing around noise until the spin cycle kicks in. Bit of a vibration issue until the revs build up.
But I always pull the com set off first - I ain't completely dumb.
Vespa 300 GTS SS
Vespa 300 GTS SS
helmet
I use a light weight cloth "liner" which I put on my head hen my helmet. Keeps the helmet liner clean. Makes sliding the helmet on easier too.
[ Time: 0.0232s ][ Queries: 3 (0.0052s) ][ live ][ 313 ][ ThingOne ]
