@billy_anthony avatar
1962 VESPA SPORTIQUE, 1980 VESPA 100 SMALL FRAME, 2000 VESPA PX 125, 1996 VESPA ET4
Hi looking for any help. My 2015 GTS 125 has recently been giving me a few problems, it stalls at traffic lights and junctions when i come to a stop also it is using a lot more fuel. The scooter runs fine apart from the stalling and fuel consumption.
There is 33 kilometers on it and it is serviced at the regular intervals most recently at 30,000.
Any advice would be appreciated.
@jet_peddler avatar
@jet_peddler avatar
I'm assuming you meant 33,000 km on it?
@waspmike avatar
@waspmike avatar
Bung a bottle (correct %) of fuel system cleaner into the tank. See what happens. It is cheap and easy and might make a difference.
Sounds like the injector is very worn or stuck partially open?
System has defaulted to rich? so could also be the Lambda sensor or....?
carnaby 125
carnaby 125
but if you using a lot of fuel and cutting out at traffic lights it seems to be running rich then if you got a injection that could be faulty but do what he said above try some fuel cleaner if else fails best getting to a garage to get them to test lamba sensor and fuel injector as you don't want to buy both incase you just need 1 part
[ Time: 0.0106s ][ Queries: 3 (0.0040s) ][ live ][ 313 ][ ThingOne ]
