Like the title says, how much oil consumption is considered 'normal' for the LEADER engine?
Before setting off to the grocery this evening, I stopped and checked my tire pressure and my oil level.
Well, my tire was down to 27psi and I added air. It was my oil level that concerned me.
I checked the oil last about 3 weeks ago. I noted that it was down from it's full mark, but still well within the hash marks.
Fast forward 3 weeks and about 900 miles and the oil level was barely touching the dip stick!
It took over 1/3 of a quart to bring the crank case back to full.
I know all engines use SOME oil. My old Ford van used 1 quart every thousand miles (it did that from the day it was new and Ford considered it normal!) and I expect the LEADER engine to do the same. But the crank case holds only 1 quart of oil! 1/3 of its capacity within 1000 miles is ALOT (at least in my opinion)
Should I be concerned by this and bring it to my dealer's attention?
-Skrap
