@rob98801 avatar
85 Vepsa PX150E with sidecar, 80 P200 with sidecar, 96 Goldwing with Hannigan Sidecar, LR87aj5, LR91aj3
@rob98801 avatar
my P200 is not charging. With 24 volts AC into the regulator I am reading only battery voltage at the output. This after replacing the regulator with 2 new ones. In both cases the same results.
I let the battery run down to 11 volts and with 24 vac into the regulator the output still reads battery voltage only (11 volts).
Suggestions?
@shoprat75 avatar
1980 P200e
@shoprat75 avatar
1980 P200e
Maybe somewhat helpful. I restored a 1980 P200e, had the stator rebuilt, and bought a new regulator. I have measured voltage from stator and it appears I'm peaking at 35v. If I measure battery voltage while running I peak at about 11.7v. I tried the original regulator with about the same results. I use the bike locally on short trips so my solution was to go to HarborFreight and buy a battery float charge for $10. I ran a couple of wires off the battery so I can hook up the charger without having to remove the cowl.
@rob98801 avatar
@rob98801 avatar
Yep< I did the same now Trying to fix the problem.
Do you have a 4 wire regulator or 5 wire?
@rob98801 avatar
@rob98801 avatar
5 wire
The regulator must have battery voltage present on the B+ (gray wire) in order to work. That voltage should appear and disappear turning the key switch on and off.
One test lead on ground, the other on the gray wire terminal.
The battery must be verified as good. Charging with a charger first helps. The charging system on a P is so chickenplop that if you have a weak or damaged battery, it can't raise the voltage to acceptable levels.
Verify both those first.
A good battery will typically flash the turn signals, blow the horn, and burn the tail light without the engine running.
@shoprat75 avatar
1980 P200e
@shoprat75 avatar
1980 P200e
This was helpful. I measured 12.05 volts not running and peaked 12.18 at high rev. Probably as good as it gets.
[ Time: 0.0095s ][ Queries: 3 (0.0015s) ][ live ][ 313 ][ ThingOne ]
