@oultondave avatar
Blue 70th anniversary Vespa GTS 300
@oultondave avatar
Rides great and accelerates fine but when slowing down from 70 ish mph it seems as if it's misfiring at about 1/4 throttle around 60 mph. Tried with ASR on and off makes no difference, it feels as if the limiter is kicking in, any ideas peeps please.
@jet_peddler avatar
@jet_peddler avatar
My BV350 does something similar but at much lower speeds. Caused by the evap system. May be causing your issue as well. I'll let more technical minds chime in and elaborate.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
When you close the throttle to slow down (especially from high speed), the intake pressure jumps to a high vacuum. If you got a small crack in the intake manifold or another small intake leak (could be a loose vacuum hose), this is the time when it will show up. You get a small gulp if unregulated air from the leak and that can cause a lean misfire. Give everything between the throttle body and the engine a good look.
-Craig
@oultondave avatar
@oultondave avatar
Thanks gents
@oultondave avatar
@oultondave avatar
So The Beasty is currently languishing at Ron Daley's in Barnsley. The misfire has been diagnosed and we need a new ECU and throttle body. Thank f**k it's still under warranty ( by three days)
[ Time: 0.0140s ][ Queries: 3 (0.0083s) ][ live ][ 313 ][ ThingOne ]
