@broken_hipster avatar
1981 P200e, S-Works Stumpjumper
Hi all,
Put in a new clutch cable and am trying to get it adjusted correctly. I understand that if the clutch lever is engaged all the way then the kickstarter will not turn anything over (sort of slips right down without catching anything) - correct?
But now it seems like every once in a while my kickstarter is not catching anything, ie: it will kick over fine for a few kicks but randomly it will slip through as if the clutch lever is engaged. Could this have to do with the clutch cable not being adjusted tight enough? Or is this indicative of a worn kickstarter gear?
Thanks,
David
@greasy125 avatar
@greasy125 avatar
could be a worn out clutch, if you're lucky. i mean, shot corks and/or weak springs will sometimes act this way.
more than likely it's a kickstart gear-- especially if you haven't replaced it.
the easiest check is to pull all the tension off the clutch cable and see if you can replicate the problem. if you can't, then you've got the adjustment wrong. if the problem persists, then jump into the clutch. it's cheaper and easier than cracking the cases for a K/S gear.
good luck!
-g
[ Time: 0.0097s ][ Queries: 3 (0.0017s) ][ live ][ 313 ][ ThingOne ]
