@older_guy avatar
Vespa 300 touring 2018
@older_guy avatar
I am buying a small 8ft trailer open from Lowes to haul my vespa 300 when I need to. my clostest dealer where I bought it is 100 miles from me and I would need to ride a lot of the interstate if i rode the scooter to them for service. I have bought the Canyon Dancer and would like to put just a small wheel chock on the trailer . what size chock should I buy, that will not hit the front fender. Amazon has a lot but I dont know how to find one for the small wheel of the vespa. Any thoughts would be welcome. or websites with what I need. I intend to bolt it down on the trailer and leave it there.
80 yr old Older guy
@jkj-fz6 avatar
@jkj-fz6 avatar
I've used these with my Zuma 125. The chock doesn't hit the brake rotor, but it's close. You'd want to be careful with your scooter.
https://www.northerntool.com/shop/tools/product_200692636_200692636
You could make something like this, and no worries about clearance:
Wheel Chuk for Vespa need help
PS You could probably put a piece of 3/4" board under the front wheel, inside the chock, to get more clearance for the brake rotor or fender.
@captain_jim avatar
2020 GTS 300 HPE
@captain_jim avatar
2020 GTS 300 HPE
I use this one from Harbor Freight...
https://www.harborfreight.com/1800-lb-capacity-motorcycle-standwheel-chock-61670.html
I removed the front bar and through bolted it in the trailer. Works great.
@troutbum avatar
@troutbum avatar
Condor makes one for scooters, but they are pricey.
http://condor-lift.com/scooter-chock
@handyman avatar
2006 GT200
@handyman avatar
2006 GT200
You can rent these from U Haul real cheap. I know probably should have taken it
off the center stand.
Years ago, before Amazon, I went nuts looking for the correct size wheel chock. I gave up and rigged my own since I, like you, wasn't going to ever remove it, and I had the lumber and hardware already in my garage.
But you could remove it if you wanted to.
Make a "U" channel with 4X4 landscaping lumber bolted thru the trailer.
Then make an identical "U" and screw it down on top of the first one.
I know, it's a bit Rube Goldberg-ish, but it's cheap, and it gets the job done. Mine was still good and on my trailer for over 10 years when I gave the trailer away to a friend after I upgraded to a Kendon trailer.
Just measure first to make sure the height of the stacked wood doesn't hit any brake parts or the bottom of the shock. I did use mine with a couple of scooters as well as motorcycles.
Yep, that's the one That I use too. Best to mod it with a couple of new holes to fit the small wheel a bit better - and if using with an LX cut 4" off the front upright as the wheel's even smaller. Very well worth the money. Holds the scoots very securely.
@dooglas avatar
@dooglas avatar
This is an excellent chock. I have a scooter trailer with two of these fitted.
[ Time: 0.0140s ][ Queries: 5 (0.0043s) ][ live ][ 313 ][ ThingOne ]
