@qascooter avatar
@qascooter avatar
Has anybody tried one of these? I'm looking at getting a CHT and it'd be nice to know what I'm revving the engine to. I almost bought a Trailtech CHT but this one is $5 more for a tach included. Hmmm.
https://www.amazon.com/SEARON-Tachometer-Temperature-Motorcycles-Lawnmowers/dp/B01COW8NGE/ref=sr_1_fkmr0_1?s=automotive&ie=UTF8&qid=1534901695&sr=1-1-fkmr0&keywords=searon+tach+hour+temp
Anybody using a combo unit out there? If so, what brand / kind?
Thank you!
@chandlerman avatar
Lucky
39 Days Since Last Explosion
Lucky
@chandlerman avatar
I run both tach & temp and would not want to have to pick either/or due to only having a single display, and it's not like you're going to be swapping between them on the fly.
@qascooter avatar
@qascooter avatar
Good point! I didn't even think about that. I'd definitely want to see both and it'd be way too difficult to change screens while riding. What gauges are you using?
parallelogramerist
parallelogramerist
A tach is handy for setting up the engine, but once it's dial in, I haven't really seen a constant need for it. If I bought that gauge, I'm guessing that 98% of the time I would have it scrolled over to the temp display.
I have tuned T5 with a Trailtech tach, and I find that I rarely look at the RPMs.
So does that gauge have a backlit display for night riding?
EDIT: it does have a backlit display!
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
I run Trailtech for both Tach & Temp, but also a Koso temp gauge which has a sensor tapped into the cylinder head. Eventually, I'll drop down to one, but that day hasn't arrived yet.
Also, while the Koso has a nice large display and a backlight powered off the 12v DC, it's powered by a CR2032 battery, which likes to die at the most inconvenient times, so the Trailtech is there as a backup for when that happens, too.
The red lighting is a small LED map light that I wired to the pilot light circuit. In the winter here, it's necessary because it's dark about 99% of the time.
In this photo, I had both the trail tech ring sensor & the Koso to compare their readings. The Koso read consistently about 5-10 degrees cooler, btw.
I use the tach for a number of things on an ongoing basis. It's as a sanity check of my speedometer. I know my speed at given RPM's because the speedo gets increasingly inaccurate past about 50 MPH.
If the engine doesn't kick over right away, it tells me if I have spark or not. It makes idle adjustments and checking timing with a variable timing igntion dead easy.
I also ran a dual CHT/Tach analog gauge for ultralight's for a while and liked the analog readings, but it eventually died and it was kind've pricey (~$75 plus shipping, iirc), so I never replaced it.
Yes, it was really 12f when I took this picture before riding to work.  The Koso only reads down to 32f.  The Trailtech reads to zero.  Guess how I know.
@qascooter avatar
@qascooter avatar
Thanks for the explanation on how you use them and the picture. I can see I'll want separate readouts so no need to wait for one or the other. I'll hook up the CHT first.
And I'm liking your night light - good one!
Thanks again!
⚠️ Last edited by qascooter on UTC; edited 1 time
parallelogramerist
parallelogramerist
I've been thinking about getting a couple of the Trailtech TTO gauges on my PX, but it seems like just buying their Striker or Vapor computer would be a better (simpler and cleaner) idea. They both have tripometers, so that would be kinda cool for checking fuel mileage as well as for road trip distances. The Vapor would be a backlit screen that would have RPMs, temp, and speed, all on at the same time. The Striker doesn't have a tach, but instead it has a volt meter. A volt meter it more important for me compared to a tach, because of all of the electric draw I have on my PX. I don't really need the extra speedometer because I recalibrated my PX speedo with a GPS, but it is a welcome addition.
[ Time: 0.0122s ][ Queries: 4 (0.0033s) ][ live ][ 313 ][ ThingOne ]
