2013 LX 150
2013 LX 150
I know my 2008 LX 150 will need a thorough going over this winter and I happened upon a nearly free 2006 motor stripped down and my thought was to rebuild the 2006(or at least get it running half decent then swap it so I could take my time on the 2008 rebuild. Well I get the 2006 belt cover off to find the ramp plate stripped out and the shaft pretty beat up. My question - assuming I find nothing else tore up - is this worth saving/ salvageable?
LX190 Friday afternoon special, Primavera, S50, too many pushbikes
Welcome to MV.
What state is your current engine in that warrants a rebuild?
@jet_peddler avatar
@jet_peddler avatar
Welcome to MV from San Antonio, Texas! No qualified answer for your question, but you'll get plenty shortly. Good, knowledgeable people here.
Re: Worth saving LX 150 motor?
That's not stripped at all.
The shaved length in the middle is how they all are from the factory.
What you have is fine.
2018 GTS Super
2018 GTS Super
Might be toast. The outer 1/4 inch of splines are critical and those look pretty bad.
2013 LX 150
2013 LX 150
Thanks for the input
znomit wrote:
Welcome to MV.
I got leaks, I got 8,000 NYC miles, I got a issue with compression, I think I need to take my time and do a lot of seals, gaskets and a cylinder kit.
[ Time: 0.0130s ][ Queries: 4 (0.0055s) ][ live ][ 313 ][ ThingOne ]
