@modernmoose avatar
GTV250 X 2
@modernmoose avatar
GTV250 X 2
Worked fine yesterday. Today... won't start. Electrical seems generally fine. Turn on ignition, can hear pump engage, lights power-up, horn works, etc. Hit start button - nothing. Not even an attempt. Battery doesn't seem remotely marginal, but no amount of leaning on the start button will have any effect.
Check kill switch, it's where it belongs. Brake engaged. Nothing.
What happened overnight?
@jkj-fz6 avatar
@jkj-fz6 avatar
Starter relay?
@miguel avatar
@miguel avatar
This happened to me once about 8 years ago on my 2009 GTV. It turned out that it was the wire going from the coil to the spark plug. Evidently, Vespa made it a little too short so it was common to break. The "dealer", who no longer exists, replaced the the high voltage wire and, voila!, it has worked ever since. Hope that helps.
Best
Miguel
Best
Miguel
That wouldn't stop the starter motor working!
First step, check all fuses and check the brake lights come on.
If starter relay clicks but no starter motor action, replace the starter relay - some are easy to dismantle and clean.
If still no click from the starter relay, bypass the kill switch and try again.
@miguel avatar
@miguel avatar
jimc wrote:
Best
Miguel
Ouch! I know that. I just misread the opening post.Thanks for the correction!
Miguel
@dmpawley avatar
2013 GTS 300 i.e.
@dmpawley avatar
2013 GTS 300 i.e.
Toggle the kill switch about 10 times and try it.
Just a thought
@modernmoose avatar
GTV250 X 2
@modernmoose avatar
GTV250 X 2
Step one: Figure out where I've buried the Haynes book so I can find things!
I get no click from the starter relay. I'll check fuses next.
Y'all are awesome, BTW.
@larrytsg avatar
1979 P200e
@larrytsg avatar
1979 P200e
Stupid question.... how old is the battery?
[ Time: 0.0107s ][ Queries: 3 (0.0027s) ][ live ][ 313 ][ ThingOne ]
