@budz avatar
GTS 300 Super ABS/ASR (sold), BV 350 ABS/ASR (crashed)
@budz avatar
seems I have a leak in my exhaust system. I have new graphite gasket so I suspect there is a leak in the manifold (cracked or rusted). Question is, shall I replace the O2 sensor too? I have 5,200 miles on a 2015 GTS...
Thanks in advance
No need at 5,200 miles. At 30,000 miles, probably, as the old one will be well stuck in there.
@budz avatar
@budz avatar
Thank you jimc!
BV 350
BV 350
Generally
Generally there is a spec on voltage on an O2 sensor. But if the 'check engine' or 'FI' warning light isn't on, most likely the O2 sensor is OK.
A bad sensor will usually trigger a warning light, and engine performance will usually suffer. Probably best to leave it alone until there is a problem.
[ Time: 0.0074s ][ Queries: 3 (0.0016s) ][ live ][ 318 ][ ThingOne ]
