My scoot fell over yesterday (center stand was in some soft tar filling a crack I the asphalt), shattering the headlight lens and breaking the headset top. A nice stranger picked up the scooter, gathered up the cracked bits, and left me a note.
The headlight still works, though the lack of a lens is obviously a problem. Any advice on the possibility of replacing the lens rather than buying a whole new unit? I am running a "Euro Vespa P series headlight 1977-2000". I see various lenses on the regular scooter parts websites but they seem to be for earlier bikes, but I am not sure if they will work and, if they will fit, how one goes about attaching them to the reflector assembly. Silicon?
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
ferrets
Panel grip/adhesive n pull it on tight with tape .... let it dry over night n remove .... Make sure ya dont over do it or you'll end up with a mess inside ya can't get off 👍☺
It'll probably be cheaper to buy the unit though..... add it up first
@frank_n_stein avatar
Jet 200, P200E (x2), T5
I've taken lenses off scooters and bikes a few times, and glued them back on with strong silicone jointing compound. Once dry, it's just as solid as the original setup. I assume windshield glue would do fine as well.
@danie avatar
@danie avatar
Just make sure you use neutral silicone, otherwise the acetic acid will corrode the reflector part of the headlight.
The bit about ferrets is making me laugh. (+: My local pet store closed recently, so I'm not sure where to get one (or what to do with it when I do).
[ Time: 0.0107s ][ Queries: 3 (0.0035s) ][ live ][ 318 ][ ThingOne ]
