Dooglas wrote:
1stGear wrote:
The mechanical key code is not in the transponder. There a plastic Code Card (the size of a credit card) with a 4 digit number that has the mechanical key code. If you don't have that card, just the number really, then a key will need to be fit, or the locks replaced.
To the best of my knowledge, no locksmith in the US can clone a Vespa key with that card that is included with Piaggio scooters. I presume it can be used in Europe to order a replacement key - or maybe it is just one of life's little mysteries.
Many locksmiths can create a MECHANICAL key from the code card. The basic lock and key system, and the associated code series, dates back to 1988. It was used in Fiat/Lancia cars before modern Vespas.
This key will turn the locks but, if you have an immobilizer, it won't start the scoot. This is true on either side of "the pond".
