There was a photo in the tips and tricks thread but it has disappeared. If your points flywheel has the magnets that overlap, then you can use it apparently.
Hard to describe without a picture but the magnets have spaces between them. The type you are looking for has 'fingers' that sort of interlace, without touching, only in one spot around the inner circumference of the flywheel.
All Content Copyright 2005-2024 by Modern Vespa. All Rights Reserved.
