Hi all! Quick backstory--had an '04 ET4 for about a month now. It'd sat in a shed for about 10 years prior to me getting it. I bought it with 1760 miles on it, just rolled 2000 miles. Starting yesterday, it doesn't want to start after sitting for a while. Been flawless up til now, and will start right back up when it's warm after riding. But flat out hard to start and won't idle when the engine is cold.
Carb is definitely clean (by Vespa service folks).
Has a new battery.
Has a new CDI (only mentioning it since it's electrical, prolly has nothing to do with anything).
Spark plug is original, I've not pulled it today, but was good and clean when I bought it and I presume the Vespa service guys didn't leave me with any adjustments to cause it to foul.
My thought is to replace the spark plug and see if it helps anything. Ambient temps in southeast Texas are in the upper 70's/low 80's F this week, so not cold-weather related. I give it the requisite two twists on the throttle before starting after sitting. I've searched here and on the web, but don't find anything that seems to fit my situation, any ideas? Thanks in advance for any help!
Edit--thought I'd add that I work less than a minute from the house. Should I find the long way to/from work to give her time to warm up? I try to stretch it out as I'm able, but can definitely extend the commute if such a short ride isn't good for it!
Dave
