I have vespa ET4, 2001, approximate 35,000 miles (odometer cable broke about 5 years ago).
The symptoms.
1) battery is 1 year old.
2) It is currently Nov.
3) battery was trickle charged over night. Reads 12.6 volt
4) scooter starts very strong. Ride to work (4 miles, 30 minutes, city mile).
5) almost at the end of the ride, head light gets dim and horn doesn't work (sign of weak battery).
5) with engine on, use spare key to open the seat cover, check voltage. With voltmeter, it reads only 10 volts with engine on.
6) if scooter engine stays on for another 15 minutes, voltage drops to 9 volt and i have difficulty keeping engine going.
7) replaced voltage regulator with spare on. Battery trickled charged over night. Symptoms (1-6) are repeated, so it is not the voltage regulator.
8 ) With battery fully charged over night, voltage regulator removed, engine ON, checked voltage of one of the three yellow wires connecting to voltage regulator. According to vespa manual, 3 yellow wires are for 3 coils from stator (alternator). I get zero voltage between yellow and ground (for each of the three yellow wires.
Repeat, to read the voltage, with engine ON, voltage regulator was disconnected. For ground, I used metal part of the scooter, so no need to question whether ground wire is faulty.
Does this mean my stator is dead?
I regret, I didn't get to check the Ohm as specified in the manual
If stator died, why would all 3 coils die together?
According to ScooterWest, Stator plate for Et4 is $60. With Flywheel and magneto, it is $153. Any advise, any experience?
https://www.scooterwest.com/catalogsearch/result/?q=et4+stator
