1969 Sprint 2011 LX50
Hi Not sure how common this is or not. 1969 Sprint takes forever to start. 20 plus kick starts with choke out. Once its started and idles for a couple of minutes, Its fine on restarts usually a kick or two. Any suggestions how to speed up the starting process?
Thanks in advance,
@fatamy avatar
59" Allstate
@fatamy avatar
59" Allstate
What is the condition of the motor ? How are the points and what is the gap ? condition of the condenser ? What is the timing set at ? Have you ever done a pressure test to check the condition of the seals ? With all that information I'm sure you'll get your answer.
1952 Allstate 1955 Allstate 1958 lambretta 1965 Allstate 1968 sprint
Slow starting
Like Amy said...need more info.
1. Check the compression: first thing I would check. Any engine that is low on compression will have a hard time starting. Scott
@l4nff avatar
1972 Vespa GTR, 1963 Lambretta LI 125, Royal Alloy GP125
@l4nff avatar
Condenser and compression. A new plug capped correctly won't harm.
Thanks for the tips Now I have a place to start.
[ Time: 0.0095s ][ Queries: 3 (0.0024s) ][ live ][ 318 ][ ThingOne ]
