After totaling out, then riding on salvage title, and then "retotaling" (long story, another thread) my 2015 GTS 300 Super Sport, I decided to push it to the side of the garage and buy a 2018 GTS 300 Super. In bright green.
Here are the physical differences I've noticed:
- the plastic covers above the brake cylinders were removed and the headset is now one solid piece
- remote control (which works about 15% of the time)
- seperate ASR button instead of holding down starter button
- ASR on/off display is now in the LCD and no longer an LED under speedo
- when removing the left plastic knee cover, there are now plastic panels you need to pop out to access the wires
Here are the behavioral differences I've noticed:
- throttle band is much more linear. my 2015 was very jerky in acceleration
- brakes are much "stiffer" and require significantly more squeezing force
- throttle is much stiffer
- runs silky smooth on initial start-up even in 30F degree weather. My 2015 would struggle for at least the first few miles
- both stall in the cold, although my 2015 appears to have stalled more often
Despite the "jerky" feel my 2015 had, so far I actually prefer how it rode and am now considering fixing it instead of parting it out. Curious others thoughts?
