I have gathered from the many effendi on this forum that the GTS ECU runs on closed loop programming up to about 6000 rpm, and at higher revs it ignores the Lambda probe and just adjusts the mixture according to engine revs, temperature and such, i.e. no feedback.
This means that a Malossi lambda emulator is only effective up to 6000 rpm, and a larger injector could enrichen the mixture above that rpm.
But I have seen ads and specifications for more recent models that say "fully closed loop". Is this correct? If so, would the ECU compensate for a larger injector, and make this mod pointless? And would a lambda emulator then have benefits beyond 6000 rpm?
Yes, I know. Someone is going to tell me it is all more complicated than that. But I would like to know what is happening here, and I would also like to know what the Malossi lambda emulator is doing with that lead that goes to he injector.
Mike
