@valvitola avatar
2018 GTV300 SG, 2012 LXV 125ie 2V, 2015 Primavera 3V 150ie and V90
@valvitola avatar
Hi everyone, Today while I was riding the front headlight detached from the cables and dropped to the floor (chromed rim and the whole headlight). I believe when installed I forgot to put the headlight clamp/retaining clip. Can someone show me how to install the clamp/retaining clip? Not sure where it goes. Thank you and sorry for such a basic question.
@gmontag avatar
@gmontag avatar
It's the clamp of evil! Ha ha ha!
Here's the best picture I've found for how it fits. Thanks to whoever posted it ages ago. It helped me a lot. Note, you have to start with the clamp slightly clear of the headset rim. The back of the clamp "sandwiches" the mount on the headset which is slightly inclined.
My headlamp also has 2 tabs on the top which locate into 2 grooves cut into the headset interior.
Good luck!
@valvitola avatar
@valvitola avatar
Thank you so much!!!!!! I just love this forum. Will try to install it tomorrow
gmontag wrote:
It's the clamp of evil! Good luck!
It's so truly frustrating to deal with. I've done it enough times to finally understand it, but the first few times induced anxiety attacks. That, coupled with the small space in the headset, makes work on the cables, shift and throttle tubes a horrendous affair. Employ a small child to do the work for you (small hands and fingers needed). If you have gotten that far, then you will experience the joy of adjusting the cables at the shift mechanism on the bottom of the engine.🤪
@ginch avatar
@ginch avatar
It's not so much a clamp as a wedge with a screw... always have a couple spare because generally they are hopeless.
My headlight hasn't fallen out for a while now because as soon as it gets the slightest bit loose I replace it.
Shittest design ever!
'74 50s x3 '87 PK125XL '92 PK50XLS Plurimatic - & - '58 AllState '68 Sprint '66(?) Super125 '72 DanMotor Super150 and '04 Bajaj LML hybrid
"Shittest design ever!" , this! All too often the threads in the top clamp bit strip out
but you can salvage the original by soldering a nut in the stamped channel and using a new Allen screw if needed from below. Straighten it like above if it's mangled.
@vma1racer avatar
@vma1racer avatar
Ahh, the "puzzle clip". The key is good tabs on the top of the headlamp rim and understanding how the stupid puzzle clip works in conjunction with the two tabs. There is also a later version for the 1970-1981 US/Canadian CEV sealed beam versions "10539" (excluding P series, but including English 100 Sport models), always missing and not reproduced.
@valvitola avatar
@valvitola avatar
Horrible system, no luck yet, I don't even understand the logic behind it
Will keep trying
@valvitola avatar
@valvitola avatar
Maybe I installed it wrong?
Your bottom bracket piece is upsidedown, it connects from the bottom, not from inside
and you must get those 2 tabs on top into their slots before you try to try to fit the bottom rim into the puzzle clamp.
⚠️ Last edited by V oodoo on UTC; edited 3 times
@vma1racer avatar
@vma1racer avatar
The squiggly part is installed upside down, take apart and flip it over. Be sure the squiggly part is under the hole/slot, the "U" shaped part is above the hole/slot. The squiggly part needs to be past the lower edge of the headlight opening, towards the front of the handlebar. Tip the two tabs on the top of the headlight into their slots and guide the puzzle clip back, capturing the lower edge of the headlamp trim.
Adjust and secure.
Not that hard.
Look at the gmontag picture.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Here's what it looks like from the bottom:
@valvitola avatar
@valvitola avatar
Oh!!!! Thank you all! Got it now.
@vma1racer avatar
@vma1racer avatar
That was the money shot. Good job SCG. That trim ring looks like the later USA style CEV sealed beam version.
Once you've got in correctly, which appears you're on the way to doing, holding the head of the nut and the clip, you can slide it forward or backward before tightening the nut to get the light beam aimed correctly.
@valvitola avatar
@valvitola avatar
I think I got it right, now need to tight things up, but I belive I understand the mechanism now!
1. The shorter part/U part goes on top of the opening.
2. The longer/squiggly part goes underneath and the screw head also goes underneath.
3. Once screwed, push forward the whole evil clamp, past the lower edge of the headlight opening. And align the top tabs of the headlight into the slots
⚠️ Last edited by ValVitola on UTC; edited 2 times
@valvitola avatar
@valvitola avatar
First time the whole clamp was not forward enough so I had not captured the trim of the headlight. Now corrected. I cannot thank you enough.
⬆️    About 6 years elapsed    ⬇️
P150/VMC177, PX200/Malossi 221, Lambretta GP125/TS1, Primavera Polini 130, Primavera Egig 180
Blimey this was useful, i just spent an hour trying to figure out how this went together before checking the forum.
It didnt help that the whole thing dropped on the floor when I took out the light and I didnt see how it went together to start with....
As ever, a cracking resource!
Cheers
Nick
[ Time: 0.0165s ][ Queries: 4 (0.0073s) ][ live ][ 318 ][ ThingOne ]
