I have seen this posted a couple of times before. But I just did it and it worked great, so I thought I'd post a reminder and a couple of photos
On my LX (and probably other models), there is not enough room between the muffler and the oil drain plug to fit the 24mm socket and standard ratchet handle.
One option, which I had used until now, is to use a 24mm wrench instead. But without clearance for a ratchet / torque wrench, you are stuck "guessing" on the tightening torque.
Another option, which I just did now, is to take a standard 24mm socket and grind about ~10mm from the top. This provides the clearance needed to get a ratchet in there.
I just completed my overdue oil change and found this worked great!
