doublegregg wrote:
Thanks so much everyone! I um... never would've thought that the $200 was even in the ball park, but your replies were very helpful. i think you're probably right about not having it done at a MC shop...... he was a nice guy, but didn't even know if the tires should be balanced or not........ i'm assuming they are, although i don't see any place to mount wheel weights.
$200 for the Vespa dealer to change a rear tire isn't unreasonable. The cost includes time for them to remove the wheel from the scooter, which might take longer than mounting a new tire.
But taking your wheel to the motorcycle shop is not a bad idea either. You'll have to remove and reinstall the wheel yourself, which is something that you can find a lot of advice for here on MV. It isn't terribly difficult. $40 is about the going rate for mounting a tire at a motorcycle shop. Most of them are competent (search online for reviews of your shop, if you're in doubt) and they will balance the wheel if necessary (small 10 inch scooter tires may not need balancing). Some shops want you to buy the tire through them; some actually prefer that you buy your tires online and bring them in (maybe they don't like to stock scooter tires, IDK).
I bring my tires and wheels, off the scooter, to a nearby motorcycle shop. I usually drop them off overnight, but the shop will change them while I wait if I'm in a hurry. It costs me $40 to $45 per wheel, and I have no complaints about their service.
Another good reason to learn to remove/replace the wheels on your scooter is that you won't have to have the scooter towed to the shop if it's not rideable; you can just throw the wheels into your car and drive there.
Good luck, ride safe, and have fun! 8)
