@25bikez avatar
2009 Genuine Stella 2T (Sold). Helix Hunting.
@25bikez avatar
After a ride, I notice my 2010 GTS makes "sighing" sounds as it cools. I can make the noise stop by unscrewing the gas cap. There's a hissing sound when I do so. Is this normal? My Majesty and Burgman had fuel injected, fuel pump engines, and they did not do this.
TIA.
Yes it's normal for the GTS to do this. Your GTS is fuel injected too. I take it the bike runs fine...yes?
My Burgman 400 also made this noise and that was fuel injected also. My Vstrom 1000 made it as did my GSX1400's. All fuel injected bikes. Many fuel injected bikes run on positive pressure in the tank, and do not have a vented tank cap. If your Burgman did not make the sighing and farting noise you may have had an early carbed version.
@web-tech avatar
@web-tech avatar
No fuel system is vented anymore, they go through EVAP systems. Even Lawn mowers.
@etchkid avatar
2015 GTS 300 ABS, 2013 LXV 150 (R.I.P.)
@etchkid avatar
My 2013 LXV was vented.
@web-tech avatar
@web-tech avatar
Not from the factory if it was a US model.
Here is a post on this website from 2010. Remove EVAP on a 2007 150LX.
Pretty sure your 2013 has one too.
LX150 Complete EVAP System Removal
⚠️ Last edited by WEB-Tech on UTC; edited 1 time
@etchkid avatar
@etchkid avatar
My 2008 MP3 has EVAP.
I knew it! I dropped it about a year after I bought it and I noticed the hole (along with some other sketchy stuff) after I got it back from the dealer. I even called and asked about the hole and they said that's a normal vent hole. Oh well. Rode on it for 5 years with no issues.
Re: GTS Gas Cap Not Vented?
TIA.
FAQ: Why does my GTS groan/moan/moo or fart when off?
@25bikez avatar
@25bikez avatar
jimc wrote:
TIA.
Thanks. It's not affecting how it runs, so I'll leave the system intact and burp the tank after I finish my ride.
No need to Burp the tank. It's meant to make that noise and the pressure does no harm at all. It's all good!
[ Time: 0.0084s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
