Kantuckid wrote:
I put a 140 on my old GTS and didn't notice it back there and will do it again on my new scoot when due. I don't buy that curved cross section/fall in stuff at all!!!
It makes the contact patch slightly larger and throws off a speedo thats off to begin with but not by enough to matter.
I've read too much evidence from more experienced Vespa ownners here that the front needs to be left at 120.
Do it if you want more rubber on the ground. Lap times? Who does Vespa laps? Braking distance is a pure guess as is top speed unless you GPS the scooter.
I guess you missed my point. COMPARATIVE braking distances, lap times, top speeds, acceleration times, maybe a Dyno run, under controlled conditions, measured and quantified, are the only way to ACTUALLY know if a change has made a difference good or bad, and is worth spending my fixed income on. "More experienced Vespa owners" is anecdotal, or hearsay, information, not data.
You don't actually know your contact patch is bigger unless you measure it and compare it to the contact patch of a 130 tire with you on the bike with the tires on the ground. It might actually be smaller because of the rounder profile (which is geometry, not faith based) of the wider tire.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=2ahUKEwii7MPdxYfgAhVFPK0KHSvTD_QQFjAKegQIAhAB&url=https%3A%2F%2Fwww.motorcyclistonline.com%2Fmotorcycle-tire-width-and-traction-video&usg=AOvVaw3j7IfhCK0NlCc6ajwjBOdK
I have to think the engineering data is out there, probably at Piaggio, to reveal how the GTS achieved its current factory configurations.
