Hi,
I've just put together a new clutch for my malossi 210 with some lovely parts from sip.
It's a 7 spring CNC basket with a reinforced circlip, honda plates and grooved centre bush. I've used sip 'sport' springs which are marked 'L' in the description.
I do find them a bit excessive in lever pull terms. A bit stiff.
I dread to think what XL and XXL are like!
There's nothing wrong, everything works well ( I'm frigging proper chuffed with it if I'm honest) and their fancy premium clutch cable is lovely too, BUT I definitely think I could get away with less spring tension.
I would like to know what other people are using
The springs in my last clutch were great but they're past their best now- they were white. Anyone know who might have sold them?
The scoot has approx 20bh p
Thanks in advance
Tony
Still looking for advice on this if there's anyone out there with an answer, really just looking for an older style spring with a weight between standard and the SIP "SPORT L"
Thanks again
Tony
@chandlerman avatar
Innovator
99 Days Since Last Explosion
Innovator
@chandlerman avatar
You could replace some of the springs with softer ones if you're looking to loosen it up. They don't all have to be the same stiffness.
Now I can see that being fine on a 6 spring or a cosa where the springs are in even numbers, alternating springs, but do you think this might be a problem on a 7 spring clutch? It strikes me that the basket might not compress squarely with 2 of the same strength springs together while the rest alternate.
Maybe it's the OCD kicking in and in reality it's not a problem.
Have you mixed springs in a 7 spring?
[ Time: 0.0077s ][ Queries: 3 (0.0016s) ][ live ][ 341 ][ ThingOne ]
