2009 Aprilia SC250, 2016 Piaggio BV350
Posts: 82 Location: N. Va, USA |
Thanks hth, but they changed the caliper for the ABS model (2106), so it uses a different pad.
2016 BV350 White
Posts: 472 Location: East LA County, CA, USA |
From AF1racing.com:
OEM Piaggio Front Brake Pads - 651253 For '16 Piaggio BV 350 ABS $35.50 Live Stock Status: Backorder, Ships in 6-8 Weeks OEM Piaggio Rear Brake Pads - 665842 For '13-'15 Piaggio BV 350, and '16 BV 350 ABS |
Question
Waht kind of rotor wear do you see with the HH pads? Reports vary between OEM-level to severe wear. Just put a set of EBC organics on my SH150, rather than HH's, due to that concern.
Wouldn't mind a bit more 'bite' than OEM, but not looking forward to changing rotors either. |
The OEM pads are from Ferodo. The Piaggio front pads for the 2016 are about $25. If you get them from Ferodo, they're about $15, but you don't get to throw away the beautiful plastic bag that says Piaggio on it. Ferodo also makes a sintered pad, as does Malossi and just about everyone now.
The real wear problems with sintered pads happened because of crappy disk material. Now sintered pads are fairly common OEM equipment on a lot of vehicles and the rotors don't wear excessively. It's sort of like leaking oil seals and synthetic oil, where the problem wasn't the oil, it was the seals. |
Posts: 8956 Location: Ashburn, Va. Home to the Internet |
Motovista wrote: It's sort of like leaking oil seals and synthetic oil, where the problem wasn't the oil, it was the seals. Have this issue on my '99 Toyota Avalon; use synthetic oil and the valve cover leaks, switch back to dino oil leak gone. |
specifically
Motovista wrote: The real wear problems with sintered pads happened because of crappy disk material. Now sintered pads are fairly common OEM equipment on a lot of vehicles and the rotors don't wear excessively. |
Ask the company that makes the pads.
I'm pretty sure most modern scooters have "hardened" rotors. The ones that were about three times thicker in the 70s and 80s are the ones that sintered brake pads ate. |
I Would, but...
Motovista wrote: Ask the company that makes the pads. |
