My 2009 Vespa S 150 is fully modified and has 50k miles on it:
190cc Malossi Engine Kit
10.5 Gram Doctor Pulley Weight
Malossi Variator with White Spring
Malossi Front Brake Pads
Leo Vince Exhaust
Vespa GT 200 Carburetor
Super thin Airbox Filter Mesh / With Internal Snorkel Delete
38 Idle Jet
100 Main Jet
I run a Vespa GT 200CC Carb
The bike is fast, very fast.....
My vespa was running like a champ but I noticed the head gaskets were leaking so after 50,000 miles on this setup, I opened her up.. The Piston Head and Valve tops had burn residue (I was running ultra lean for 6mo unknowingly, and got the engine way too hot, exhaust was glowing... the 2 engine headgaskets were torn and had a chunk missing including the metal being ripped off.. the cylider walls were like "Brand New".. No scorching and the piston was still Perfectly seated like new.. I couldnt believe it, nor how the engine was still running like a champion with blown gaskets that were clearly leaking pressure... lots of blow back out of it..
After sanding off all the burn residue and installing new gaskets, she went back together with ease.. I re-adjusted the valves..
The bike runs like Brand new.. again the cylinder walls and piston were still very tight and in like new condition amazingly.. no issues, runs super quiet...
Unbelievable that after 50k miles, all the engine needed was some minor cleanup and new gaskets.. these vespas are Serious Workhorses.. I abuse mine, run it wide open throttle for long periods of time, have many passengers, all weather conditions from 0 degrees to 105...
I came to the conclusion that the bike will deteriorate outside (panels, mounts, bolts, exhausts etc..) faster than the engine will die.. ive already installed over 3 exhausts lol...
The malossi kit is rock solid.. I change the oil every 3k miles or year..
Take care of your vespa and it will take care of you!
Cheers[/quote]
BV 350
BV 350
Maybe
Did you check the head and mating cylinder surface to make sure they had not warped or eroded? Sometimes a blown headgasket is a symptom of head and cylinder surfaces that don't match up. Especially if the engine had been overheated.
If the problem is not too severe, can usually correct it with a piece of oiled wet-or-dry sandpaper on a piece of glass.
Probably worth checking if the next gasket starts leaking.
2007 LX150
2007 LX150
Do you use the stock 150 intake manifold with the GT200 carb? What about the air box and air inlet manifold?
Yes checked the head and mating surface, there was a little erosion but I filed it down quite well...i checked all the surfaces and cleaned up all the old gasket material.
I use the stock carb outlet and air tube and air box. Just have to rotate the carb side to side back and forth to work it into the rubber housing.
@waspmike avatar
@waspmike avatar
Re: Maybe
Or an old bathroom tile or even in the bathroom.
[ Time: 0.0095s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
