Hi,
I want to update the rear light on my restoration and prefer the smooth look of the GS rear light than the standard VBB version.
But does anyone know how you would wire up the internal assembly? I assume the unit takes Festoon bulbs but how do they securely fit inside?
www.scooter-center.com/en/3330997r/taillight-siem-vespa-vna2t-vba1t-till-no-110485-gs150/gs3-vs4t-till-vs5t-no-0087589 is the light in question
Re: Vespa GS Rear Light
Ant1985 wrote:
Hi,
If you want to get technical about it, late GS150 and GS160 used the same taillight as a VBB. To answer your question: yes, festoon bulbs. They secure the same way as any festoon bulb secures.
@sea avatar
'61 Cushman GS150, '62 GS160
@sea avatar
To get really technical, though, the link you sent is a rear light for a GS 150 (for 1958). The GS 160 (I have a '62 Mk 1) looks like the attached pic (three pieces), which is also the light on the VNBs and VBBs (from 1961 on).
I think his point is that he doesn't like the "acorn" style light. I'm with you though. Even if I don't like the look of a part, I'll still keep it to maintain originality. I like the acorn light very much, but that's me. I will, however, change out an original part for a reproduction part if function is an issue. For example, the original HT coil on a GS160 is shit. I use one that is made in Taiwan, and it has never failed after years of use.
[ Time: 0.0090s ][ Queries: 4 (0.0029s) ][ live ][ 343 ][ ThingOne ]
