Mon Aug 27, 2018 9:16 am
1986 Honda Elite 150 (sold), 2009 Scarabeo 200 (sold), 2007 GTV "Pazzo"
Mon Aug 27, 2018 9:16 am linkquote
I'm on the verge of getting a RAM X-Grip phone mount to mount my iPhone (a 6S) on the exposed metal handlebars of my GTV but have some GTV=specific questions (which as far as I can tell haven't been addressed in most RAM mount posts here, which deal with the GTS handlebar configuration).
First the basic info. The entire package seems to consist of 4 parts:
#1 a RAM rail-base with a U-bolt which clips on/around the handlebar, and a round attachment ball
#2 a double-socket Arm, which connects the rail-base to the actual X-Grip
#3 the X-Grip itself (correctly sized for my phone, doh)
#4 a safety Tether, to keep the phone attached to the Grip instead of flying free in the event of any equipment failure
My specific questions are -
With regards to #2, the connecting Arm, in comes in 2 sizes - longer (3.7"), and shorter (2.4"). The shorter version is slightly pricier (who knows why).
I've attached photos of both so you can see what they look like. Which size do you think would work better with the GTV's handlebars?
With regards to #1 (the rail-base), it comes in either Zinc-coated metal or Stainless steel - the Zinc a little cheaper, the Stainless a little pricier - they look identical --- are there any long-term downsides to the Zinc?
What are your thoughts on this, fellow GTVisti?
the longer double-socket connecting arm
the shorter double-socket connecting arm
Mon Aug 27, 2018 10:45 am
GTS 300, Buddy 125
GTS 300, Buddy 125
Mon Aug 27, 2018 10:45 am linkquote
I think it dependson personal preference on exactly what you want the attached item to be.
Mon Aug 27, 2018 10:58 am
Mon Aug 27, 2018 10:58 am linkquote
I agree with you, cdwise
Unfortunately I don't really have any personal preference one way or the other - but am hoping for some practical feedback from people who have used similar set-ups on their GTV handlebars --- and (hopefully) might be able to tell me what works for them, or what doesn't, or what they might recommend.
Mon Aug 27, 2018 11:40 am
GTS 300, Buddy 125
GTS 300, Buddy 125
Mon Aug 27, 2018 11:40 am linkquote
FWIW, I have both and which I use depends on what I've got in the ram mount. Granted I ride a GTS but I do the same switching on my other scoots/motorcycles so I don't think it is makes much difference whether you are riding a GTS or GTV on which you want to use.
Mon Aug 27, 2018 11:46 am
Mon Aug 27, 2018 11:46 am linkquote
Just can't put my $800 phone on one of those. What if you drop the bike even at a stop, the phone is going to go flying out of the X-Mount.
Mon Aug 27, 2018 11:54 am
GTS 300, Buddy 125
GTS 300, Buddy 125
Mon Aug 27, 2018 11:54 am linkquote
I put my iPhone X in one but with a tether and a military spec drop case on it. Though to be honest the best case I ever had for mounting an iPhone to a bike was the Lifeproof iPhone 6 case that locked using its own mount not the Xmount. I also have AppleCare.
Mon Aug 27, 2018 12:39 pm
2006 250 GTSie
2006 250 GTSie
Mon Aug 27, 2018 12:39 pm linkquote
I don't have much specific input to your questions, but I do with RAM. I use one for my iPhone 8 when at the race track in my car. I've never had an issue with it. It holds very well and has never failed.
I was going to try to get the parts to adapt it to my GTS, but I've decided to try the QuadLock mirror mount.
Mon Aug 27, 2018 1:08 pm
2009 GTV 250
2009 GTV 250
Mon Aug 27, 2018 1:08 pm linkquote
I used this mount on the left brake on my GTV. I can get pics after work.
https://www.rammount.com/part/RAM-B-309-1CHU
Edit: I splurged on the chrome mount and chrome double socket (short size), to match the GTV bling, but both are available in black for considerably less.
Mon Aug 27, 2018 1:52 pm
2019 GTS 300 Touring
Mon Aug 27, 2018 1:52 pm linkquote
Just last night I was looking for ideas on where best to place a Ram ball mount.
Came across a video from Scooter West that was helpful.
Take a look here:
Paul
Mon Aug 27, 2018 4:17 pm
Mon Aug 27, 2018 4:17 pm linkquote
Take a look here:
Paul
Thanks, Paul. This is helpful.
Thank you, jjhenry5
Thank you, PDX Scoot Scoot
Thank you, cdwise
Maybe the moral of the story is that it's nice to have a mounting system which can be used on multiple vehicles. I hadn't actually thought of that but it makes a lot of sense
Mon Aug 27, 2018 4:41 pm
2020 GTS 300 HPE
2020 GTS 300 HPE
Mon Aug 27, 2018 4:41 pm linkquote
I have both the longer and shorter double socket arms on my GTS (yes, not a GTV, but...) - both work just fine. I use an X-Mount on one and a camera mount on the other. Easily interchangeable, if desired. I have mine mounted on the mirror stalks, but either would work fine as a handlebar mount, too.
Because you can adjust the angle, you don't have to go just "straight up" with those arms. The one I have my phone mounted on is angled in just a bit to keep the phone behind the windscreen.
There have been a couple times I have forgotten to snap the tether in place, and the phone hasn't moved a bit.
Mon Aug 27, 2018 4:49 pm
Mon Aug 27, 2018 4:49 pm linkquote
Thankxxx Captain Jim ! your answer is truly helpful ... and I'm going to make the plunge. Appreciate your input.
Mon Aug 27, 2018 8:30 pm
Mon Aug 27, 2018 8:30 pm linkquote
I so worry about that same thing for my $1200 phone (iPhone x/256 GB)
Miguel
Mon Aug 27, 2018 10:14 pm
2017 GTS Super
2017 GTS Super
Mon Aug 27, 2018 10:14 pm linkquote
If you drop your bike the phone is the least of your worries, use the tether.
If you have any thoughts about bar end mirrors the standard M8 RAM ball mount will fit in your existing mirror mounts. I understand an M8 nut will be required for proper spacing. Going this way on my bike. All the goodies from SIP showed up this afternoon.
Mon Aug 27, 2018 11:26 pm
Mon Aug 27, 2018 11:26 pm linkquote
Being the OP or Original Poster, I appreciate the words of concern from both WEB-Tech and Miguel about potential damage/s to my iPhone from unforeseen road damages - but I tend to agree more with Mr. Thompson's comment - that in the event of an accident, my cell phone is truly, the least of my worries. I also have to agree with his comment that in many cases, the protective 'tether' may (hopefully) keep the phone from flying away.
I've actually taken the trouble to read through hundreds of comments on Amazon from actual users of RAM-Mount X-Grips on motorcycles and scooters and the truth is, statistically speaking, s**t occasionally happens. There is no perfect guarantee of safety and I have accepted that; what really interests me more (why I started this post in the first place) was curiosity about other owners' opinions as to what they like or don't like about their respective X-Grips.
I'll take the safety question one step further and confess that every time I get on my scooter and ride out on a street or highway, I have mixed feelings - both of exhilharation and enjoyment (as in: 'damn, this is fun!') and also a small dose of spine-tingling fear since I've experienced enough semi-close-calls from car or truck drivers who literally didn't see me...that I'm just happy to survive.
In that sense, probably, getting any kind of smartphone mount may not be the smartest survival strategy - since merely having one more cool tiny screen to occasionally glance at - might mean that in those micro-seconds when I was glancing down at my iPhone, I might momentarily neglect a potentially dangerous change in traffic around or ahead of me. So, my Inner Paranoid-Self asks my Risk-Taking-Self if he's really sure that he needs another 'distraction'?---
And my answer to myself is: I think so...and I hope I can live with it.
But yeah, I also get it wouldn't be any fun to lose my iPhone - and the statistical truth (from scores and scores of mini reviews on Amazon & other sites) is that, occasionally, X-Grips fail - and your smartphone falls or goes flying and winds up toast or a brick.
Moral of the story for me: when you go out, keep your eyes open and look down the road
Life sure was easier before we had smartphones ... wasn't it?
Tue Aug 28, 2018 3:32 am
Vespa GTS 300
Vespa GTS 300
Tue Aug 28, 2018 3:32 am linkquote
Three thoughts:
1. Seriously? When you think about an accident your first thought is the phone? Reminds me of me in my early 20s... crashed my NX650 due to a patch of freaking grapes on the ground mid curve... got up, bleeding from both my knees and a foot and the only thing that was on my mind was "please tell me I didn't trash my favorite leather jacket"
2. Dropping at a stop is extremely unlikely to release the phone from the RAM holder at least if you're using the rubber thinghie. In a more dynamic crash where the vespa is moving at the time of the collision... that's not good for the vespa and for the you but the phone probably prefers that kind of collision where the forces happen in all 3 dimensions vs only along the Z axis. I've dropped my phone and learned that the best thing to do is kick it mid air to add a significant forward component to it's motion... besides I can think I'm Ronaldo while I do it. Only times I've seen iphones die in a fall was from even short heights falling straight down on the screen.
3. Forgot my 3rd point but It was a good one. Oh yeah... get a Wells Fargo credit card and use it to pay your cell phone bill... automatic protection for your phone(s) free of charge
Tue Aug 28, 2018 3:57 am
Tue Aug 28, 2018 3:57 am linkquote
Actually my concern was not dropping the phone or a crash but destroying the phone from the shake, rattle and impulsive shock it will take being mounted on the handle bars. Also you are blasting it with dirt and road debris. But honestly I've not looked into it. And if I was interested, I'd be looking for reviews of how my specific phone survived after 1000s of miles. I bet some of the cannon ballers could help with that answer.
Another possible answer is to just get a motorcycle-specific GPS.
I also agree with you Miguel about diverting attention away from driving. Just my opinion.
Cheers
Miguel
Tue Aug 28, 2018 8:37 am
2009 GTV 250
2009 GTV 250
Tue Aug 28, 2018 8:37 am linkquote
With the tether, I trust the X-grip, but most of the time I don't bother. I don't need to see a map except for longer trips in unfamiliar areas. I've got a communicator, so I can get audio GPS directions with the phone in my pocket if needed.
Anyway, here is how my mount looks:
Tue Aug 28, 2018 9:28 am
Tue Aug 28, 2018 9:28 am linkquote
Thanks for the pictures, jjhenry5! they are most helpful, appreciate it!
Btw, I love the color of your GTV 8)
Tue Aug 28, 2018 9:38 am
2021 Vespa GTS300 HPE Racing 60's, 2019 BMW K1600GT Sport, 2019 Ural Gear Up
Tue Aug 28, 2018 9:38 am linkquote
Looks good and they are pretty rock solid when it comes to gripping iThings (and others). I find the issue with the iPhones is the battery gets sucked if you have Google Maps up. I keep meaning to get the USB knee pad adapter. Longer trips though I usually use the C650GT for that has a Garmin GPS plugged in. With the Vespa I tend to get by with a Sena and the turn by turn directions in my ears. I can and have used the Garmin on the Vespa when needed, 4 hours battery life.
I wish that little GPS made for scooters would come to NA. Blows my mind that is hasn't though. Don't they want to make money? I mean the mapping is already done so how much work would it take? I think it's the Zumo or something like that?
Canada does constantly get screwed though by products not coming here so I guess I'm used to it.
Tue Aug 28, 2018 12:23 pm
Tue Aug 28, 2018 12:23 pm linkquote
EDIT: I see you have exposed round handlebars. This company also has mounts for those regular round handlebars. I thought you were mounting on the "body" of the handlebar area.
This mount worked great on my MP3's handlebars. They sell smartphone cases that clip onto the mount. Very secure.
http://www.interphone.com/en/products/accessories/spare-mount-for-scooters/34089
Tue Aug 28, 2018 12:26 pm
Tue Aug 28, 2018 12:26 pm linkquote
Not if it just falls over and your phone goes sliding across the asphalt
Tue Aug 28, 2018 1:24 pm
GTS 300, Buddy 125
GTS 300, Buddy 125
Tue Aug 28, 2018 1:24 pm linkquote
FYI, I was out on the BV today with my iPhone X in the mount. With the move of the on/off button from the top to the side when I was on a bumpy road an SOS was sent out. Apparently if you press the button 5 times quickly it will auto send an SOS to your emergency contacts. It was very secure in the mount but in the years I've owned an iPhone it had never happened to me before so I thought I'd let you guys know.
Tue Aug 28, 2018 4:00 pm
2017 GTS Super
2017 GTS Super
Tue Aug 28, 2018 4:00 pm linkquote
The tether should prevent this however there is always Murphy's Law.
⬆️    About 6 months elapsed between posts    ⬇️
Wed Feb 13, 2019 4:10 am
2018 GTV300 SG, 2012 LXV 125ie 2V, 2015 Primavera 3V 150ie and V90
Wed Feb 13, 2019 4:10 am linkquote
Hi, what brand of mount is this? I havent seen chromed bases bt RAM.
Wed Feb 13, 2019 8:40 am
2009 GTV 250
2009 GTV 250
Wed Feb 13, 2019 8:40 am linkquote
It is also from Ram: https://www.rammount.com/part/RAM-B-309-1CHU
Wed Feb 13, 2019 9:58 am
VSX, Stella 177, Stella 150, VNX1T, V9B1T
Wed Feb 13, 2019 9:58 am linkquote
https://www.wish.com/product/5b8560fe8bf2491632ed5448
works perfectly. includes usb charging port, and a ball end with a tab that has a hole for mounting by bolt to a surface. I just went and bought a ram mirror bar mount adapter to install on the mirror bar instead of at a bolt with the included mounting hardware. The official ram bar mounting part I purchased was as much as this whole knock off ram phone mount system from wish.
Thu Feb 14, 2019 5:26 am
2014 GTV 300ie
2014 GTV 300ie
Thu Feb 14, 2019 5:26 am linkquote
I have the setup on my GTV with the longer connector. It give me a lot of flexibility positioning the phone or GPS. Also went with the stainless u-bolt because I live close to salt water and have had rust issues with plated parts.
Thu Feb 14, 2019 7:44 am
Thu Feb 14, 2019 7:44 am linkquote
Miguel.... I use the X mount between my GTV & GTS. Also have long & short. Both work. I feel the short is more stable. Be aware... The ball mounted to the X mount WILL fail. The phone ended up in my lap twice. Tether won't protect this issue. Ram sent a replacement both times. Good customer service. Hopefully they strengthen the bridge between the ball and the X mount.
Sat Feb 16, 2019 5:24 am
Sat Feb 16, 2019 5:24 am linkquote
Thank you I hadn't seen the chrome line! I have two Rams on my LXV, the black ones, one for my iphone with a short arm and one for my gopo with a long one. Both set at the mirrors. I will buy this chromed one for my GTV. Thank you!
[ Time: 0.0603s ][ Queries: 8 (0.0219s) ][ Debug on ][ 209 ][ Thing One ]
