@fatbear5 avatar
1977 P200, 1980 P200
@fatbear5 avatar
I understand that the default setting for a 1980 P200 is 23 degrees BTDC. With the timing marks aligned, is that the default 23 degree setting? If I wanted to change the setting to 18 degrees BTDC would I rotate the stator clockwise?
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Correct, turning the stator clockwise will retard the timing
@chandlerman avatar
Innovator
400 Days Since Last Explosion
Innovator
@chandlerman avatar
Marks aligned should be 23 deg BTDC. I'm not the trusting sort when it comes to timing, however, so I would verify TDC and then adjust timing from there and validate with a timing light.
[ Time: 0.0104s ][ Queries: 4 (0.0043s) ][ live ][ 343 ][ ThingOne ]
