LX 150
LX 150
At random times, at slow rolling speed, when I make a turn the steering feels like i have a front flat tire - but I don't. Tire is properly inflated. It's a strange feeling, like the front end is gonna slip out from underneath me. Then it just goes away - for days. I'm stumped. If anyone has a suggestion, I'd appreciate the help. thanks in advance.
13k miles, 2009. I've had all regular maintenance.
@collinsd65 avatar
LX 50
@collinsd65 avatar
LX 50
The shock in your front suspension is in good working order?
Shock might be toward the end of its life. Not hard to replace.
Do handlebars shake?
@25bikez avatar
2007 Kymco People S 250. Helix Hunting.
@25bikez avatar
More Info?
Age and brand of tire?
Tire clean? No Armor All or Tire Shine on it?
Check the front end for play?
Axle/suspension joint condition?
Steering/fork head bearing?
Maybe a ply delaminated or the tire carcass is breaking down.
Just off the top of my head.
LX 150
LX 150
I've got a set of Michelin City Grip on there, about 6-8 months old. no tire dressing, nothing like that. I can't feel any play anywhere. handlebars don't shake. shocks seem ok as far as I can tell, haven't noticed anything particular other than this odd circumstance.
@jkj-fz6 avatar
BV400, Primavera 150
@jkj-fz6 avatar
Not likely to be the cause, but is the tire mounted in the right direction?
Are reaching the point of freewheeling? which would feel strange when in a slowspeed turn.?
@collinsd65 avatar
LX 50
@collinsd65 avatar
LX 50
Re: LX150 Front Tire Feels Flat
micksf wrote:
At random times, at slow rolling speed, when I make a turn the steering feels like i have a front flat tire.
Took me a while getting used to slow turns on an LX.
I had 3 other scooters, not vespas.
Was it wet, cold those days you felt the sensation?
2011 LX 150ie 2013 LX 50 4v
Believe it or not, full throttle acceleration on an LX 150 while making a 90 degree turn from a full stop, can cause the front wheel to get light enough to wash out some. But if this is what you're experiencing, it would only be happening under low speed full acceleration conditions, not while at a steady speed or coasting.
@web-tech avatar
@web-tech avatar
That use to happen on my Honda Elite 150, I would put as much weight on my feet as I could as far forward as I could on the floor boards. Helped.
LX 150
LX 150
appreciate all the suggestions so far, keep 'em coming if you've got them. I feel it's mechanical. This is my second LX150 and bought this one new 10 yrs ago. I live in San Fran and ride all year around, rain or shine. I have not changed my driving routine in any way to warrant a strange scoot response. this sensation is only recent, been experiencing it only the last few weeks. it happened first time about a month ago. I immediately went to the service station, thinking I was really low on air. but that wasn't the case, I shook my head and continued on with my day. then it happened again about a week later, and then again the day before my post. I keep pulling over expecting to see or feel something wrong. I tug on the wheel, I've checked/tightened all front end bolts, looked for anomalies in the tire. I did double-check, the tire is mounted in the correct rotational direction. I'm thinking maybe of rebuilding the front hub? was hoping someone else experienced this so I could pinpoint it. of course, I'd prefer not to have to dump a bunch of $$ making unnecessary repairs.
I do find all suggestions helpful, keeps me thinking.
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Are you sure it's the front?
@northernerbill avatar
lx 50
lx 50
My Xmax rear tyre needs topping 1 or 2 times a week.
The front tyre hardly ever.
But the moment I leave or forget to do top up the rear I know because the steering goes heavy like the front is under inflated......but it's the rear!
@sacto_monkeyboy avatar
GTS 300 Super
GTS 300 Super
I like to overinflate slightly. Again, all the other suggestions and discussion seems to be more valid than mine but you mentioned "proper inflation" and I do like to be a bit more full in my tires.
Could be why when I run over a nail or sharp object that I have to replace tires a LOT and I try to carry Slime or some other emergency inflation type of thing.
LX 150
LX 150
hmm, interesting. I will double check the rear tire. thanks.
LX 150
LX 150
Issue Solved
Turns out the engine mount bolts were loose and the engine was shifting while turning. Got those tightened up and all is good again. Thought I'd mention the fix in case anyone ran into this issue in the future.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
Always the last place you look.
[ Time: 0.0141s ][ Queries: 3 (0.0067s) ][ live ][ 343 ][ ThingOne ]
