Vespa LX50
Vespa LX50
Hi everyone,
I'm after some help with my LX50, it's my first scooter and this is my first post so I'm a complete newbie in both worlds!
This morning all of my indicators failed, there were no glitches beforehand so this was out of the blue. I've done lots of searching on the web prior to posting on here but have not found any solutions, most diagrams show a separate relay which I don't appear to have.
I've managed to strip down the front end to reveal the electrics, and as I mentioned , there's no obvious relay. I seem to have a regulator (a silver metal box?) with an eight pin connector block on one side and eight wires feeding into seven of the terminals.
All connections seem fine, all the way back up to the indicator switch on the handlebars so something has failed.
Would the regulator be at fault, or would all the electrics connected to it fail at the same time if that were the case?
Based on that question, does that only leave the switch as an alternative culprit or am I overlooking something else?
Thanks everyone in advance, any help is greatly appreciated.
@melt avatar
Vespa 2013 LX125, 2017 GTS300
@melt avatar
Its all here
Lx50 indicators problem
Vespa LX50
Vespa LX50
I did read that thread before posting but felt like I needed to explore the problem more before resorting to that solution.
Regardless, I have now installed a new relay as shown and that didn't fix the problem.
I took it upon myself so put a new rocker switch in and that didn't immediately solve the problem either. At first there was no life in any of the bulbs, but after a few attempts the right hand side have suddenly sprung to life but the left hand bulbs are still dead.
I have checked the wiring as best I can and all seems ok, can any one shed any more light on this please? (no pun intended)
Thanks.
Re: LX50 Indicator problem
dan_c wrote:
Would the regulator be at fault...?
As they say where they made the thing, Si.
Vespa LX50
Vespa LX50
Can't see where it's made but I've attached a photo in case that helps. It has 'Mitsuba' on it, I guess that's the make?
If one side works but not the other then the regulator (which provides the switching signal) isn't at fault. It'll be somewhere in the wiring - almost certainly a duff connector.
I was refering to where the Vespa is made.
The best and quickest way to rule it out before spending a lot of time on workarounds is to borrow a known good one from someone and plug it in. If that fixes the problem, and it usually does, it's the regulator. If not, keep looking.
[ Time: 0.0169s ][ Queries: 4 (0.0042s) ][ live ][ 343 ][ ThingOne ]
