Primavera 150
Primavera 150
Hi guys,
I know there is an older topic about this but it doesn't seem to help...
So... I was stupid enough to throw my keys into the trunk of my 2015 Vespa Primavera 150 - and close it - and to make it worse, I don't know where my second key is... I've already searched everywhere but to no avail.
How can I open my trunk without keys without destroying my scooter?
Any help is very much appreciated.
@sacto_monkeyboy avatar
GTS 300 Super
GTS 300 Super
Who's your insurance provider? Are you AAA?
Primavera 150
Primavera 150
I'm a member of AAA... but can they help with this?
@finn avatar
Vespa Primavera 150 (2019)/Mp3 Sport 500 HPE (2019)
@finn avatar
AAA is for the person not the vehicle. so if you call as a member and say you are locked your keys in your bike, they should be able to send someone to help get your key back.
Worth a call for sure.
@paddlenround avatar
Any competent locksmith should be able to open the seat lock. There really isn't an alternative. AAA will unlock it as part of your membership. However, the price for a locksmith to unlock it is likely around $50 should you need one.
On some models if you reach up under the left cowl just ahead of the airbox, you can feel the plunger that the solenoid pushes to open the seat.
Also, IDK what models use a seat release inside the glove box, but if your ignition hasn't been moved and is 'vertical', you can push on the ignition and/or the ring surround and maybe get lucky and the glove box pops open.
@mike_holland avatar
GTS300 Super 2023 Beige
If your Prima is set up the same way as a GTS, then there is a simple wy to open the saddle without keys. I'll send you a pm.
Mike, it's been allowed by the mods to post it in the open since at least 2011.
But this urban legend of not to post how to do it keeps living on...
I didn't know. I've just seen a long discussion about this on the German Vespaforum, with many members requesting PMs on how to do it.
I've been on this forum for yonks, but have never seen this tip.
@michaelg avatar
ET4 187
@michaelg avatar
ET4 187
i'm a long time member of the german forum.
i know the deal.
a locksmith might charge a small fortune. in germany, the suckers want 200 bucks....
By 'trunk' do you mean topbox or under the seat? If under the seat then this might help if the Primavera seat is similar to the LX:
Locked my keys in the 150 LX Seat
If you mean topbox then you can remove the hinge pins. You might have to file some material away from each side.
@michaelg avatar
ET4 187
@michaelg avatar
ET4 187
jimc again, hits the nail on the head.
waiting now...
Re: Locked my key in the trunk
HansWurst wrote:
Hi guys,
no need to destroy the scooter, just the topcase will do.
Primavera 150
Primavera 150
Thank you all!! I actually found an easy way to open it without breaking anything. I'm so happy now!!
If someone ever has the same problem with a 2015 Primavera PM me...
It'd be even more helpful if you posted your solution on this thread.
There isn't any prohibition on posting security info - thieves don't take care to open up your bike without damage, they just use brute force.
The boogerman doesn't lurk on MV, believe me as I worked with criminals for years and it's not their kind of "thing".
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
In Kansas you can call the taxi cab company and they are very agile with that tool. Price $30. They con't do houses though.
[ Time: 0.0138s ][ Queries: 4 (0.0028s) ][ live ][ 318 ][ ThingOne ]
