1999 ET4
1999 ET4
Hi all
For some easy internet points, can I ask about the Walbro carb jets ET4 125.
Are they meant to have a hole right the way through them? Noticed tonight that the idle jet https://oem-parts.hu/en/upload/cache/l/g/5/lg51-000-071-284-idling-jet-34.jpgdoes not have a hole through the centre i.e. one that goes through the top and out the screw end
The other jet does although it was completely blocked solid. The side and top holes are open on both jets.
@pinkscooter avatar
@pinkscooter avatar
Jets are supposed to have a hole through the center. unless its clogged and needs cleaning. The size of that hole determines how much fuel the carb delivers.
1999 ET4
1999 ET4
Thanks for the help. The jet is really blocked then. The top holes are all ok. Thinking I will re drill the main hole in the base. does anyone know the diameter of the hole?
Everywhere is out of stock for the Walbro jets in the UK apparently.
[ Time: 0.0079s ][ Queries: 3 (0.0013s) ][ live ][ 318 ][ ThingOne ]
