So recently did a fulll service on my Xmax 125.
Oil, final drive oil, oil filter, belt, rollers, brake pads.
Whilst stripping down the variator to access the rollers I noticed that (mostly on the roller side) the faces of the variator where worn and had troughs built into it, so essentially altering the gearing.
I had noticed recently a slight drop in performance. Mostly mid range to fulll power. So this means after the new variator and belt it pulls like a train from launch and goes right up to full speed effortlessly.
But.......
If at 35/40mph I have to back off behind a car (mostly on a hill) it's slow to essentially drop a gear and pick up again.
The variator change (after 20k miles) has transformed it a lot.
I'm now thinking the plates on the receiving clutch end might easily be as worn and not letting the belt release and slide back out of the trough.
I haven't had the clutch assembly out yet, but does this sound likely.
I've attached a picture of the variator plates and the marks highlight the groves worn over time.
