It finally happened. Dead battery. Got my 2013 GTS 300 in May 2014 and it has just under 8000 miles now. I pulled the original battery and noticed a lot of corrosion around the positive terminal. I cleaned it up and gave it a complete charge from my trusty 35 yr old Sears charger.
It took the charge and showed 12.7V so I reinstalled it (greased the positive terminal) and it started just fine. After a short ride I returned home and shut it off and tried a restart. Everything fine, started right up. With the engine off, and after 10 minutes voltage was 12.7. I'll check it again over the next few days before reinstalling cover and mat, but here's the gamble. With a nearly 5 yrs old battery is it on it's last leg, or can I squeeze 1-2 more years. Don't want to get stranded miles from home and no ability to push start.
Note: Always garaged, used nearly daily, no battery tender.
Thanks!
12
