Electric ignition on my ET2 suddenly stopped working. Can hear 1 click from relay when I try ignition.
Checked voltage at battery terminals seems to be 12.5 before starting, drops when trying ignition to 8V or so (brake light dims too) and voltage unstable when revved (oscillates around 18V). Though might be battery so Tried a car battery but no success.
Replaced regulator- but no improvement.
When kick-started the indicators are flashing too fast
I was sure it was the regulator. Any advice on how to track down the problem. My thoughts are could it be an earth problem - if so where? Could the regulator I swapped in by failing too? Could it be a problem with the relay?
Grateful for advice on what to do next.
