So this '59 GS came into my life and has been collecting dust for the last couple years in my garage. Whatever processing needed to happen apparently did because I got the bug to pull it out and start tinkering.
All I know for sure is my dad had someone paint Sophia Loren on it and put a new seat on her. It has not run in the last 35 years. There is some issue with the clutch cable and how the guy that painted it ran it (or was unable to run it) through the frame. Working towards pulling the handle bars off to see what the deal is with that. It appears the only problem is potentially the outter housing isn't all the way up inside, the inner cable moves freely and is attached at the grip but not the clutch side.
I know someone tried to get it going back in the 90s but if I recall correctly they weren't getting a spark and couldn't figure out why (after reading a bit I found you have to have a battery to get a spark?)
Anyway, I come for advice... should I fiddle with it and see if it can make fire or should I fully dismantle and rebuild the engine, clutch, etc and start from scratch?
Thanks in advance for any help!
