@mish avatar
Piaggio Beverly 350
@mish avatar
Piaggio Beverly 350
@mish avatar
Piaggio Beverly 350
@mish avatar
Piaggio Beverly 350
bv350
bv350
agreed
I did this mod about few years ago. The best mod I ever done. You can see the road so much better!
@jet_peddler avatar
@jet_peddler avatar
I think I'd like to order these.
Which "Color Temperature" and "Socket Type" are correct for the BV 350?
Thanks much for your help.
@mish avatar
Piaggio Beverly 350
@mish avatar
Piaggio Beverly 350
6000k
H7
Greetings from The Netherlands.
@nautiker avatar
'14 Piaggio BV 350
@nautiker avatar
'14 Piaggio BV 350
Mish - Thanks for the info!
@telomostro avatar
2019 BV350
@telomostro avatar
2019 BV350
I was jus wondering if these bulbs fit right in or did you have to modify something...?
@syd avatar
@syd avatar
I was wondering if these are designed for the BV350, or if they are generic (and put light all over).
@mish avatar
Piaggio Beverly 350
@mish avatar
Piaggio Beverly 350
It is not special for the Beverly, also for other scooters with an H7 connection. It fits exactly under the plastic cover of the Beverly and you do not need any extra parts. Only use it for normal light, high light is also possible but makes no sense. Incidentally, you get 2 lamps, you can use both.
@breaknwind avatar
Red Devil SH150i (11,000)
@breaknwind avatar
Do you ride without the rubber cover. Doesn't the rubber cover block the airflow to the unit? Those things need air flow to cool them.
In the add.
"Seven-piece flower heat sink design increase cooling rate, extend work lifetime".
@mish avatar
Piaggio Beverly 350
@mish avatar
Piaggio Beverly 350
No, i ride with the black cover. Everything is ok.
[ Time: 0.0180s ][ Queries: 4 (0.0091s) ][ live ][ 318 ][ ThingOne ]
