WEB-Tech wrote:
Madison Sully wrote:
WEB-Tech wrote:
Allens wrote:
breaknwind wrote:
Now there is a high percentage of water remaining. Fill with 50/50 premix coolant. Whatever's left in the bike dilutes the premix.
If I worried about it, I'd repeat the process, but add full strength coolant. Then you'll have created a 50/50 mix in the radiator, no?
Just remember, as soon as you get the coolant over a 50/50 mix, you have a corrosive fluid in your cooling system.
Never guess, measure properly.
And unless the fluid is nasty I just drain and flush every two years and don't flush. If I was going to flush I would do it with coolant mix, not water though. It's not hard to do with a trip to a boating store to get an engine winterizing kit.and the right couplers.
Where do you get that going over 50/50 being "corrosive" idea? Most coolant brands I see suggest a maximum of ~70% coolant for highest freeze point suppression.
Was always taught not to go over 50/50, but reading says if needed you can go up to 70/30. I am sure it is more corrosive that 50/50 mix though.
And a 70/30 mix does lower your boiling point.
As WEB-Tech says, depending on the type of coolant you use, going over a 50/50 mix can be detrimental to the engine. Mostly this is because it alters the cooling properties of the coolant, making it less effective as a coolant. Some coolants can become more corrosive to some types of engine components in mix ratio's above 50/50, but this all depends on the engine materials used and the type of coolant in use ie: HOAT, NOAT, OAT or many other types of coolant. But that's not very common these days and that's why it's always best to follow manufacturers instructions on the type of coolant to use and the mix ratio.
If anyone is running a weaker than recommended mix ratio, as long as it is not off by much from the recommended ratio, it's ok. But don't go too far from the manufacturers recommendations because remember your water pump depends on not only good quality coolant to lubricate it's seals but also the right mix strength.
