Vespa rally 200, 1975
Converted by previous owner to 12 volt, non battery, Ducati piaggio flywheel (off a px150/125 looking at the fins)
Piaggio stator plate, rewired about 4 years ago by beedspeed (hardly used since then, less than 100 miles).
Has had new Ducati cdi (the blue one) new HT lead, cap, plug.
Ok that outlines the engine, so my problem is simple, sometimes it starts first kick after being left for a month, sometimes it won't start for love nor money.
It always appears to the same problem, I take off the plug kick over...no spark.
I tinker around for ages, checking leads, changing plugs etc, and then if I'm lucky I kick it over and there's a spark, if I'm unlucky there isn't.
Drove over to my girlfriends today, drove fine, I had to mess around to get it started, but once going it was great, then when I went to leave it wouldn't start ....yes you've guessed it, no spark, no amount of bump starting made any difference, dried different plugs/caps...nothing, then I saw a spark whilst checking the plug, put it back in and momentarily it fired up then instantly died (tried bump start ...nothing!)
Pushed it for about a mile up and down kerbs then just for the hell of it I tried to bump it again and brrrrmmm , it nearly took my arms off, drove me home perfectly (about 2 miles)
So I'm at a loss as to what the problem is
All help advice greatly appreciated
Troy
