Hi
Ive just resuscitated a 2004 GT. It has got a flat spot sometimes (particularly when engine is cold) when going from tick-over to running on "main jet". Pulling out of a junction say, I have to "nurse it" a bit to ensure it doesn't cut out - then off it goes!
Question is this. Is the "flat spot" likely to be caused by the weights and rollers - or could it be the carburettor?. Is there a jet in the carburettor that is in between the tick-over and running on a fairly full throttle? Or could the variator weights and rollers be the culprits?
Many thanks in advance
Hugh
