Hi,
I'm planning an everyday street use build and my big question here is; do I go for an aluminum or cast cylinder?
Starting with a Primavera ET3 so I already have electronic ignition.
Suggested build;
* Polini 130 cylinder kit - Alu or Cast iron
Looking to choose between the Polini Race 130 (cast cylinder) and the Polini 130 EVO (alu cylinder). Both have alu heads.
* 24mm phb carb
* Mazzy race crank
* Short 4th DRT christmas tree
* XL2 clutch
* No mod to flywheel
* Keeping SIP Road banana
If I can afford both, what are the pro's and cons?
I'd hate to loose the normal smallframe feeling with a low idle and typical sound.
