@youthcore avatar
18 GTS300 Super/78 P200/12 Stella 4t
@youthcore avatar
Hey guys, when I upgraded from a GTS250 to my 18 GTS300 I opted for the PM Tuning exhaust but was hoping for a little louder experience. My 250 had a LV exhaust with the db killer removed. Is this something I can do with the PM?
Thanks!
GTS 300 super i.e
GTS 300 super i.e
Re: Vespa PM68 exhaust baffle removal
Thanks!
Let's see if I got this right: You want the PM 68 to be louder?
Don't know if there are any louder pipes than the ones from PM Tuning. Next step is riding with just the downpipe fitted.
@youthcore avatar
@youthcore avatar
[/quote]
Don't know if there are any louder pipes than the ones from PM Tuning. Next step is riding with just the downpipe fitted.[/quote]
It's not as loud as my old Leo Vince, not even close.
Remove the DbKiller.
@youthcore avatar
@youthcore avatar
Do you happen to know if it's just the one small screw at the end of the pipe? I removed the screw but the db killer didn't budge. I wanna check before I over muscle the pipe.
It should be tack welded in place like the restrictor in a two stroke exhaust, designed to be broken away without a lot of effort.
GTS 300 super i.e
GTS 300 super i.e
As you can see here ( https://www.scooter-center.com/en/pm1006c/db-eater-pm-tuning-pm61-pm62-pm66-pm68 ) the db killer is called the entire endcap unit, held by four rivets.
No, it isn't. It's the long hollow pipe. That's most of what comes out when you pull the Dbkiller out.
@youthcore avatar
@youthcore avatar
I might not be understanding. I removed the screw and still cant pull the db killer out. Am I missing something?
If you've taken the screw out that's at the bottom and goes into the bolt you see in the photo, pull the center pipe straight out. It's that simple.
@youthcore avatar
@youthcore avatar
For sure. I'll keep yanking until it frees up. Thanks!
@rob_g avatar
2008 GTS250, 2009 S150, 2017 GTS300Super, 2006 GT200
@rob_g avatar
How'd this ever work out? Did it pull out? How'd you like the sound once it was out?
@youthcore avatar
@youthcore avatar
It took a bit of muscle but I was able to pull the db killer out. It sounds great! I'm still partial to my old LeoVince pipe, but this one looks so much better.
@rob_g avatar
@rob_g avatar
Excellent. Thanks!!
[ Time: 0.0226s ][ Queries: 4 (0.0168s) ][ live ][ 318 ][ ThingOne ]
